Quick connect fittings leaking
   / Quick connect fittings leaking #1
rob in ore
Western Oregon
Kubota B2320
The fittings that supply the backhoe (Woods BH77, dealer installed about 8 years ago), have started to leak a little more than I'm comfortable with. The leak is most noticeable when the backhoe is removed and the supply/return lines are plugged into each other. These hoses and fittings are only used for the backhoe. They are only connected/reconnected three or four times a year.
Could the fittings be worn out with such light usage? Is there something else I should look for? The hoses and threaded connections are dry.
Can I just change the fittings on the tractor or should I change the mating set on the backhoe at the same time?
The real culprit turned out to be one of the crimped connections. I guess they weren't as dry as I thought.
I replaced the o-ring. Thank you for that, I didn't know there was such a thing in there.
When the leaked returned, I wiped it all down again and was able to see it while working the control lever. A new hose and it's fixed.
2020 EZGO GOLF CART (A50324)
2020 EZGO GOLF...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
E-Z Trail 675 Grain Cart (A50514)
E-Z Trail 675...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
