Quick connect fittings leaking
   / Quick connect fittings leaking #1
rob in ore
Western Oregon
Kubota B2320
The fittings that supply the backhoe (Woods BH77, dealer installed about 8 years ago), have started to leak a little more than I'm comfortable with. The leak is most noticeable when the backhoe is removed and the supply/return lines are plugged into each other. These hoses and fittings are only used for the backhoe. They are only connected/reconnected three or four times a year.
Could the fittings be worn out with such light usage? Is there something else I should look for? The hoses and threaded connections are dry.
Can I just change the fittings on the tractor or should I change the mating set on the backhoe at the same time?
The real culprit turned out to be one of the crimped connections. I guess they weren't as dry as I thought.
I replaced the o-ring. Thank you for that, I didn't know there was such a thing in there.
When the leaked returned, I wiped it all down again and was able to see it while working the control lever. A new hose and it's fixed.
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2016 Ford F-150 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2012 International Day Cab Truck Tractor (A50323)
2012 International...
John Deere 693 Corn Head (A50514)
John Deere 693...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
