Quick connect fittings leaking
   / Quick connect fittings leaking #1
rob in ore
Western Oregon
Kubota B2320
The fittings that supply the backhoe (Woods BH77, dealer installed about 8 years ago), have started to leak a little more than I'm comfortable with. The leak is most noticeable when the backhoe is removed and the supply/return lines are plugged into each other. These hoses and fittings are only used for the backhoe. They are only connected/reconnected three or four times a year.
Could the fittings be worn out with such light usage? Is there something else I should look for? The hoses and threaded connections are dry.
Can I just change the fittings on the tractor or should I change the mating set on the backhoe at the same time?
The real culprit turned out to be one of the crimped connections. I guess they weren't as dry as I thought.
I replaced the o-ring. Thank you for that, I didn't know there was such a thing in there.
When the leaked returned, I wiped it all down again and was able to see it while working the control lever. A new hose and it's fixed.
2014 Ford Explorer SUV (A50324)
2014 Ford Explorer...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2012 VOLVO VNL...
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
JOHN DEERE 250 SKID STEER (A51242)
JOHN DEERE 250...
