Questions about 2013 Massey Ferguson 1533 Rear Remote install
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #31
Got a call back. He said all they have on it is a power beyond adapter sleeve. It's like 3"s long and $97s.
Ugg
I found this photo from when I was doing my 1540. Maybe it helps a little bit?
Ugg
So if I understand correctly the lines being pointed to with the green arrows are high pressure lines going to your power beyond and the yellow is you return line?
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #33
No. That lowest hose you identified in yellow, is connected to the pressure port.
Upper 2 hoses not identified, because my panel is in the way, go to return port and sump port.
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #34
Return port
OK. So white Upper is return, yellow lower is pressure. Correct?
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #36
Yes.
I don’t see your sump port though. It’s different than mine. I’ve indicated where the sump port plug is located on mine
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #37
On mine, there’s also a downward facing hex plug, on top of the return port casting, that gets replaced with a “diverter plug “.
Are you talking about this plug? Thus picture is from the top side of the last picture you posted.
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #39
None of my business but why on earth don't you get the brand and model number off of the loader valve and get the diagrams and descriptions of everything about it on-line? Which ports are for what, etc.
Where is the brand and model number located on it. Everything the dealer sends me a diagram on it. It's the wrong part
2006 Dodge Ram 1500 Pickup Truck (A56858)
2006 Dodge Ram...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
2025 YOUERT YOU12 1-Ton Mini-Excavator with dozer blade (New/Unused) (A59225)
2025 YOUERT YOU12...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
1997 Moxy MT30 Haul Truck (A55272)
1997 Moxy MT30...
Brent 420 Grain Cart (A56436)
Brent 420 Grain...
