Questions about 2013 Massey Ferguson 1533 Rear Remote install
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #31
Got a call back. He said all they have on it is a power beyond adapter sleeve. It's like 3"s long and $97s.
Ugg
I found this photo from when I was doing my 1540. Maybe it helps a little bit?
Ugg
So if I understand correctly the lines being pointed to with the green arrows are high pressure lines going to your power beyond and the yellow is you return line?
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #33
No. That lowest hose you identified in yellow, is connected to the pressure port.
Upper 2 hoses not identified, because my panel is in the way, go to return port and sump port.
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #34
Return port
OK. So white Upper is return, yellow lower is pressure. Correct?
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #36
Yes.
I don’t see your sump port though. It’s different than mine. I’ve indicated where the sump port plug is located on mine
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #37
On mine, there’s also a downward facing hex plug, on top of the return port casting, that gets replaced with a “diverter plug “.
Are you talking about this plug? Thus picture is from the top side of the last picture you posted.
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #39
None of my business but why on earth don't you get the brand and model number off of the loader valve and get the diagrams and descriptions of everything about it on-line? Which ports are for what, etc.
Where is the brand and model number located on it. Everything the dealer sends me a diagram on it. It's the wrong part
AUGER FOR GRAVITY WAGON (A52708)
AUGER FOR GRAVITY...
2017 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2017 Kenworth T800...
2017 JOHN DEERE 544K-II WHEEL LOADER (A52709)
2017 JOHN DEERE...
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
2020 ATOKA TRAILER & MFG. 40+5 LOADER TRAILER (A58214)
2020 ATOKA TRAILER...
