Questions about 2013 Massey Ferguson 1533 Rear Remote install
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #21
I have an old Ag tilling trailer that has alot of older hydraulic parts I can rob off of it. I made a temporary setup for now. Here's my Seatbelt throttle for it.
I am not able to follow exactly what you did (but that's OK as long as it works!) There is something rather undesirable about having to hold your joystick back (or in any direction) with a seatbelt or any other means. That says you must be disconnecting your normal front end loader hoses such that you can attach your "connect back at the rear" hoses. Then using the joystick to cause fluid pressure where you want it.
But I get it -- temporary is temporary. And amazing progress really. Pretty resourceful.
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #22
What brand kit did you use and did it come with downloadable instructions?
Massey Ferguson. That’s what I meant with “MF”. Got it from the dealer. I don’t recall there being any downloadable instructions, other than a paper copy that came with it
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #23
Can I do this or is there a MUCH easier way of just adding rear hookups? Hopefully I didnt explain this too much like a neanderthal that It didnt make sense. Thanks.
Take a look here
Take a look here
Thank you for that info.
OK so according to this paragraph and my interpretation of it. All I need to do to have a "power beyond" is to intercept and tee off of this hard line going up next to the FEL valve and into the top of the 3 point.
I believe this is the line they are referring to. It's the only line going past the valve towards the rear end.
If I understand correctly I'll need this setup... is the plug circled in blue where I need to connect my return line?
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #28
Did you call a Massy dealer to check price on a power beyond kit? I don’t remember it being super expensive
I have and with not a great outcome. They couldn't find one. They said it was a dealer option on new tractors but they don't do them anymore, as an aftermarket setup on older tractors. I called them today after reading your post and talked to them for a little bit. They're going to dive into it a bit further and see if they can find something for me. Thank you
Got a call back. He said all they have on it is a power beyond adapter sleeve. It's like 3"s long and $97s.
EZ loader trailer (A56857)
EZ loader trailer...
SAMSUNG REFRIGERATOR / FREEZER (A54757)
SAMSUNG...
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
2021 International MV607 Dump Truck (A56858)
2021 International...
(2) JOHN DEERE 8 LUG RIMS (A52708)
(2) JOHN DEERE 8...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A55973)
2014 Ram 2500 4x4...
