Question on drill bits??
/ Question on drill bits?? #31
I was at HF and found a set of Silver and Deming dirll bits for fairly cheap - I want to say $20 - sale of the normal HF price of $40. Anyway I picked them up.
What the heck does Silver and Deming mean?
I was at TSC and they had one Silver and deming bit for $20!??
Where is a good place to buy cutting oil? I will try Napa tomorrow.
/ Question on drill bits?? #32
/ Question on drill bits?? #33
</font><font color="blue" class="small">(
)</font>
Silver & Deming Manufacturing Co
I bought a set from HF and found them to be usable..I did bend two shanks when the work came loose..but that wasn't a problem with the bits.....
/ Question on drill bits?? #34
)</font>
/ Question on drill bits?? #35
<font color="blue"> What the heck does Silver and Deming mean? </font>
"Silver and deming drills are general purpose drills with a reduced shank to fit into a standard chuck, typically 1/2". Often used for portable drills with standard chuck capacities. All S&D drills are 6" long with a 3" flute length. Alternate terms are blacksmith drills or prentice drills. "
Above Quote from this site. Click Here
/ Question on drill bits?? #36
/ Question on drill bits?? #37
Drill doctor......... Great tool. I wish I had one 30 years ago! Took me a while to "tune-up" thirty years of dull bits, but once you get them up to snuff you can keep them sharp and at the correct bevel etc.
/ Question on drill bits?? #38
/ Question on drill bits?? #39
</font><font color="blue" class="small">( What the heck does Silver and Deming mean?)</font>
Silver & Deming Manufacturing Co.
Salem, Ohio
This company could trace its history back to 1854, although the "Silver & Deming" name does not date back that far. The titular heads were Albert R. Silver and John Deming. In the later history of the company, Emmor W. Silver was a principal; he was perhaps a son of Albert.
Silver & Deming was created in 1867 or 1868 after L. A. Dole had died, and Dole, Silver & Deming was renamed. In about 1874, Silver & Deming became Silver & Deming Manufacturing Co. In 1890, the company reportedly split, with one part becoming Silver Manufacturing Co.
Silver & Deming made a variety of machines that were primarily aimed at wheelwrights: hob-boxing machines, spoke-tenoning machines, etc.
Silver & Deming apparently invented the large-size twist drill bit with a turned-down shaft so they can be used in a chuck smaller than the bit's cutting diameter. They did not patent this idea, so the idea was quickly copied by others, but these bits are still called "Silver & Deming drills".
/ Question on drill bits?? #40
Salem, Ohio
40' High Cube Shipping Container (A60463)
40' High Cube...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
International S1900 (A61307)
International...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A61307)
2019 Takeuchi TL8...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
