question on brake controller wireing
/ question on brake controller wireing #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I'm going to graft on a cheapy brake controller on my ford 5000. I've already got the relays for running power to it, and power / ground and brake power wire. Last line to run is the brake pickup / sense wire.
I'm going to use either a feeler switch or a magnetically coupled switch for the brake 'sensor'. My only question is this. The line from the back o fthe controller that is the brake sensor.. that normally hooks to the vehicle's brake switch line.. I'm running mine thru an improvised switch.. does it need to see battery power.. or does it need to be grounded?
thanks
Soundguy
/ question on brake controller wireing #3
I am pretty sure it needs to see +12 volts.
kennyd...Thanks for the info.
Also johnk, thanks for the links!
Soundguy
/ question on brake controller wireing #5
thanks
Soundguy
The last couple trucks I've installed brake controllers in were pre-wired. Just plug and play! No need to think either! Going back to the last one I wired without the aid of factory installed plugs, the sense wire tied to the HOT wire curcuit going to the brake lights from brake light switch.
That seems to be the consensus. Now that I think about it.. i can just unplug the harness off the back of the brake controller in my truck, throw a meter ont he sensor wire and then hit my brake pedal.. but I think it's already answered.. etc.
thanks
Soundguy
(2) FIFTH WHEEL PLATES (A65643)
(2) FIFTH WHEEL...
2017 Mitsubishi Fuso FEC72S Landscape Truck, VIN # JL6BNH1A9HK003132 (A65563)
2017 Mitsubishi...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
Parker Gravity Wagon (A66285)
Parker Gravity...
2020 CATERPILLAR 289D3 SKID STEER (A65053)
2020 CATERPILLAR...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
