"If the thermal protection takes 8 minutes to reset after blowing off at 2 minutes, how does it decide to cool down in only 6 minutes after blowing off at 4?"
Because (theoretically) if you stay
at or UNDER the duty cycle, it
should NOT reset at all - the thermal reset/cutout is there for when you exceed it...
Projects - too many to mention, but not all are welding - my old hoe needs 7 more cylinders rebuilt, some hard tubing replaced, more added for high flow (2 projects that need hyd. motor) brakes redone, swing tower bushing/pin redone, QA finished for front bucket/
grapple/forks/flail/brush bucket, starter solenoid/ignition switch replaced -
Then there's the other two tractors and implements - some welding, some swearing, BFH therapy...
But at the moment I'm prepping a spot downhill from the existing shop for another 40x60 - hopefully closed in before winter so I can actually work on the other stuff without waders and scuba gear
Just finished shooting the site with the laser, took 3 rows of 5 elevations and found max difference of 18" - averaged the 15 points and got 80 yards of material just where the actual slab will go, about 150 yds total. Guess I'm gonna need a grading permit along with all the other crap
Duty cycle?? I'd LOVE to hit the duty cycle on my MM252 OR my old copper-wound AC-DC (Solar brand, by Century) stick machine. That one's 100% at 160 amps, tapering to 20% at 250. It's a bit heavier than an inverter though :laughing: - If I actually FOUND the cutout temp, it might mean I was making some progress
Later, gotta go murder some grass (remember the zero turn deck repair? Still working
)... Steve
