Question about duty cycle
/ Question about duty cycle #11
Well, I know I can go over the duty cycle of my 175miller connected to a 60amp fuse panel. I have had it shut down several times. I will admit that for the majority of the welding I do, its only a few inches here and there, but once everything is tacked up, its balls to the wall until the welder, or I, shut down. I have also had my Lincoln idealarc, 250/250 shut down trying to tig 3/8 aluminum, ( even blowed the 60amp fuses a time or two), but never using 1/8 rods. What can I say, I abuse things.
/ Question about duty cycle #12
Perhaps we could liken the situation to having two different sized tractors required to do identical tasks within their limits. While both tractors would get the job done generally the components of the larger unit should outlast the smaller one..
Thought I would throw the word "tractor" into this post a couple of times. :)
Terry
/ Question about duty cycle #13
OK, now I'm confused -
If "weldOR" is the (qualified) person who is using a "weldER",
Why isn't a "tractOR" the person who is driving a "tractER" ?
Stupid english language... :D ...Steve
/ Question about duty cycle #14
OK, now I'm confused - If "weldOR" is the (qualified) person who is using a "weldER", Why isn't a "tractOR" the person who is driving a "tractER" ? Stupid english language... :D ...Steve
From Wikipedia:
Shinor: one with obsession with but not limited to the grinding, sanding and polishing of metals in preparation of the welding process.
Terry
/ Question about duty cycle #15
Bad enough NSA thinks they need to know how many sheets I use to wipe with, now freakin' Wiki is watchin' too??!?
It's almost enough to get me to weld dirty stuff :confused:
OK, I said ALMOST - :D ...Steve
Speaking of shiny stuff, I got tired of waiting for CL to help me out, so this should be here Monday -
Hougen Portable Magnetic Drill 2-3/8" Fabricator Swivel Kit HMD917SK - Ohio Power Tool
Now I can stop tryin' to figger out how to get tractor implements to fit on my mill table so I can use annular cutters. :D
/ Question about duty cycle #16
Hougen Portable Magnetic Drill 2-3/8" Fabricator Swivel Kit HMD917SK - Ohio Power Tool[/URL] Now I can stop tryin' to figger out how to get tractor implements to fit on my mill table so I can use annular cutters. :D
Nice. A Hougen is def on my wish list. In the mean time I picked up a used cheapo Ryobi POS for $20 and lopped 8" off the column.
I used it to drill 5/8" holes in my welding table (á la welding web). Couldn't use my annular cutters tho....
Terry
/ Question about duty cycle #17
Actually there is no such word as Weldor. A person who uses a "Welding Machine" is a welder. Somehow this "weldor" BS got started and refuses to die.
If you mean to reference the equipment it is a welding machine, welding torch, etc but the person using it is always a WELDER.
/ Question about duty cycle #18
Terry
Terry, you do know they make a adapter to use annular cutters in a drill press. My large craftsman actually has a 3/4 chuck I can put a annular cutter into.
/ Question about duty cycle #20
Lincoln are the ones who came up weldor to distinguish the difference between a machine and the person using it. It can be confusing sometimes. It doesn't matter what duty cycle a machine has if the person using it has a lower duty cycle. ;)
4'x6' Stack of Sheet Metal (A60463)
4'x6' Stack of...
2023 Big Tex 16GN (A60462)
2023 Big Tex 16GN...
KMC 6 Row Peanut Reshaker (A60463)
KMC 6 Row Peanut...
2024 GREAT DANE FREEDOM LT FLATBED TRAILER (A59823)
2024 GREAT DANE...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
2015 FREIGHTLINER  2500 4X2 SPRINTER VAN (A59906)
2015 FREIGHTLINER...
