Pushing over dying pines with FEL
   / Pushing over dying pines with FEL #11
Ive seen people pushing trees with FEl and the tree split in half with the top of the tree coming down on the cab.
thats why i hired a large excavator and operator to fell my large ones. fast, clean and safe
   / Pushing over dying pines with FEL #12
The roots on pines are generally shallow, and the root ball will extend out past the lower limbs.
On a 24 inch diameter pine, that would put the root ball at 8 feet or so away from the trunk. Which means that if you were capable of pushing the tree over............the root ball will flip your tractor. I can almost guarantee it.
Thanks for all the advice guys. The needles are still on the trees, but they are mostly brown and dying. I've never seen a pine recover after it gets that bad. The only experience I have with a chainsaw was from a really big water oak in my yard after hurricane Ike a few years ago. My "nice" neighbor volunteered to help me get rid of it because it fell from his yard. He ended up helping me cut up all the limbs that were suitable for firewood (for his fireplace) and leaving me to deal with all the big stuff alone. By the time I figured out he wasn't coming back, the tree was pretty dead. So I bought a chainsaw and that's when I discovered dead wood is harder to cut than the green stuff.
Actually I do have another option. It will involve some work, but I can move my stuff (no permanent structures) out of harm's way and just let them rot and fall. I didn't want to do that because it will take so long and I really like the location. Plus there's a good chance they will damage other trees around them on their random way down. I'm now leaning toward cutting a > in the direction I want them to fall and then cutting from the other side. How deep should the > be? I'm thinking 1/4 to 1/3 in. Probably move my stuff anyway even if I do try cutting them down.
   / Pushing over dying pines with FEL #14
If you've never felled trees before, and are in a tight area............don't attempt it, only bad things will happen.
I used to be a logger, I'm all too familiar with the dangers.
But if you are adamant about doing it yourself.........do some studying first:
http://forestry.about.com/od/chainsaws/ss/fell_tree.htm
http://www.wikihow.com/Fell-a-Tree
http://www.ehow.com/how_4893933_fall-tree-direction.html
Felling pines: http://www.gardenguides.com/109234-fell-pine-trees.html
   / Pushing over dying pines with FEL #15
Simply cutting a V notch in a tree doesn't guarentee the direction of fall. Things like wind, which way the tree is leaning, which side of the tree has the most weight from branch growth, all affect the direction it will go independant of V notch/backcut direction. The best assistance though still no guarantee of fell direction with a questionable tree is drive wooden or plastic wedges into the backcut to assist the tree in starting to move in the desired direction.
Have the proper safety gear in use and be sure to have a clear path to run in any direction when a tree starts to move, in case it goes in an unplanned direction.
As for pushing them over with any small tractor, it'd never happen. Same for pulling or pushing stumps out. you wont have the traction, weight or horsepower needed to accomplish that task based on my experience. We have a 955 cat dozer and having tried on stumps as small as maybe 16 inches, and 3 to 4 foot tall, it wont budge them as a rule.
How to Fell a Tree Using a Chainsaw
How to Fell a Tree: 14 steps (with pictures)
How to Fell a Tree in Any Direction | eHow.com
Felling pines: How to Fell Pine Trees | Garden Guides
Thank you for the links Don. I'll do a lot of research first, but I probably will try to drop them myself. The area won't be tight after I move my stuff, but at least maybe I can avoid damaging some of the nicer trees I have left. You wouldn't believe how bad it is. I honestly think I'm losing about 1/3 of my pines. See:
Texas drought kills as many as half a billion trees
I also like the wedge driving thing Charlie mentioned.
   / Pushing over dying pines with FEL #17
I agree you should have someone else (professional) cut them for you. Maybe have him drop a few (The more dangerous ones) while you watch. You will then see the danger we are trying to portray for you.
Then if you feel comfortable you can fell one. You will have enough work just cleaning up the felled trees. The dangers you will encounter then are just as bad but different in nature. I take it you don't have a lot of saw experience...
Limbing large trees can be scary too.
My tractor has a steel cab. Once I tried to push over a dead maple stem ten-twelve inches at the stump and 35 feet high. I suceeded in snapping the top eight foot section off. It landed sideways on my cab, ending up straddling the loader arms. IF I WAS IN A OPEN CAB... not good.:eek:
You can learn a lot from a professional in a day and the $ will be well spent. Tackle the big ones after you have some experience.
   / Pushing over dying pines with FEL #18
As others have said, felling the trees is a much better option that pushing them over. Widow makers would be your biggest danger - you're likely to survive having your tractor flip, you're much less likely to survive a large branch falling a great distance and dropping on your squash. And those falling limbs are almost a certainty if your using under-sized equipment, as instead of a clean push over you're going to be rocking the tree to get is loose and tipped.
And if you have no experience felling trees, felling dead tress is *NOT* the the best learning situation! Dead trees will often snap rather than hinge, and as stated above, the danger of widow makers is much higher.
   / Pushing over dying pines with FEL #19
Your welcome.
Pines are rough to cut. The limbs are generally low to the ground, and when the tree falls......it can roll in any direction.
Always plan and clear your escape route first.
Use plastic wedges made by Stihl. Do not use metal ones, one touch with the saw and you'll be sharpening for a long, long time.
Look at the saw closely. There sould be a 'felling sight' on it. Once you learn to use it, your gold:thumbsup:
Be careful when limbing after the tree is down......the tree will roll...........I once got wedged between two downed trees that way. The only thing that saved me from being crushed was that I turned the saw.........and the bar stopped the rolling tree. Had to wait for the skidder to come back to winch the tree away from me.
   / Pushing over dying pines with FEL #20
Pushing over dead trees is risky. They have been known to break in half and come backwards. We had a neighbor killed 20 years ago pushing over trees with a Case backhoe. :(
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
New/Unused Stand on MX-MRW14 Wheel Loader (A57453)
New/Unused Stand...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
