Push ring PTO coupling
/ Push ring PTO coupling #21
When you say hold the ring back. The only movement at the ring from its normal position was towards the tractor. Do I push the ring forward towards the tractor then push the pto assembly onto the tractor spline cheers John N
No, you pull the ring back towards the driveshaft and at the same time pushing the whole drive shaft towards the tractor and on the the PTO stub shaft. That is what makes things a little difficult. Pulling the ring back in one direction while pushing the drive shaft in the opposite direction.
One thing that hasn't been mentioned when you 'pull' the ring back is to use both hands... (after lubing both the PTO shaft & the coupling with a lanolin lubricant) I cradle the coupling in the palm of my hands, then 'pinch' the ring back between thumb a fingers...
Once I've got it sliding onto the shaft, I can release the ring either before or after I've advanced it regarding the PTO groove. You can hear & feel it lock into the groove.
:thumbsup:
/ Push ring PTO coupling #23
Spend 30 minutes cussing at the thing......
That is just considered foreplay. It all comes down to the right technique. Most of the exposed items that need lube to outlast the elements I use marine grade waterproof grease.
/ Push ring PTO coupling #24
The only one I have with a "PULL" ring is an extension I use when I hook my brush mower to the quick hitch. The mower shaft was already cut too short for using a quick hitch. I have to remember to install the extension before I back up to the mower or it's a fight.
My finish mower shaft had a small diameter button so I tack welded a flat washer on it. Made a world of difference.
/ Push ring PTO coupling #26
It's definitely not a grease issue, the safety cowling on the implement is such that you can only fit one hand into it. Totally fine for push pin PTO coupler but when you need two hands to pull the ring back it's physically impossible.
/ Push ring PTO coupling #27
Hey, I agree that some of these "safety" cowlings and guards are so confining that there is no way you can get your hands in. They must think it is safer if the operator can't get it hooked up to begin with.
/ Push ring PTO coupling #28
Now you're onto something.
/ Push ring PTO coupling #29
Someone on the forum said they drilled a hole in quick connect so they could put a pin in it to hold the ring back. Install the yoke on the splines and pull the pin out and the ring snaps into place. Pretty clever I thought but can’t find the posting. Was considering doing it because my mid mount mower has one of these and you can’t get two hands on the coupling so doing it with one hand is really tricky
/ Push ring PTO coupling #30
I don稚 know about you all ... I致e got 5 machines with this type of pto hook up. No problem with any .. I keep the drive shaft it self greased ( lubed) for easy movement along with all grease fittings. I pull back the ring .. mine all lock back. Install on pto shaft push and click ! That痴 it. No BS like you people are talking. I personally like them .. but the other type is fine also ... just my 0.02 cents.
Hi Guys
All good now the PTO been on and off several times with ease. A squirt of dry lube did the trick. Into digging a few post hole now. Thanks for your help. Cheers John N
/ Push ring PTO coupling #32
Hi
I have a PTO with a ring which slides towards the tractor when the PTO shaft is placed on the end of the PTO. How do I get it on the tractor spline to the grove and take it off again at the end of use. The push pin PTO I have is a breeze in comparison. Cheers John N
Count me in on the push pin side. I just bought a new Land Pride cutter and it has (had) one of the collars you have to pull back to release. It wasn't too hard to unhook because both hands were pulling in the same direction. When you are hooking back up it required one hand to pull back on the collar and the other one to push in the opposite direction. I probably could have done it easily 50 years ago but old age and arthritis made it very difficult now. I bought a new yoke with the push pin release, messed up the universal joint getting it out and had to replace it too. Why they ever changed the things to the collar type release I an't figure out. I would think it is more expensive to make but what do I know? My wife says not very much.
Its all good and working fine now.
Quote. Whats the definition of a wise monkey? answ = a monkey that dosent monkey with another monkey's monkey. Am I right or am I right.
/ Push ring PTO coupling #34
Hi
You change it to the push button type. That's what I had my dealer do. Those pull back ring things are just WRONG!
Ralph
/ Push ring PTO coupling #35
I have both and I've never had an issue with either of them. Both slide on and "click" in place easitly. I do keep both styles lubed good though.
/ Push ring PTO coupling #36
The best thing I did with the push ring on my 660 rototiller was to take the push ring apart and replace the spring with a lighter one. That alone made it about 50% easier to install.
/ Push ring PTO coupling #37
I don't care for WD40 for most things, but I do like to use it as a cleaner and light lube on PTO shafts and couplings. It flushes away dirt and grease and leaves a light clean film which is all that's needed. The worst thing you can do is over lube the shaft and coupling with heavy oils or grease, which collect dirt and clog the springs.
/ Push ring PTO coupling #38
I do the same thing, and it's just fine for me too...
SR
/ Push ring PTO coupling #39
Same here wd or just a can of liquid wrench. I've seen guys use grease and it's a mess
/ Push ring PTO coupling #40
Light oil applied from a spay can works fine for me. Years of doing so never created a problem with button or ring collar style couplings.
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
2022 EZ-GO ELITE...
2020 KUBOTA KX080-4 EXCAVATOR (A65053)
2020 KUBOTA...
John Deere 6155R (A64126)
John Deere 6155R...
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
2006 INTERNATIONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
