PURCHASING SKIDSTEER AND MULCHING HEAD
/ PURCHASING SKIDSTEER AND MULCHING HEAD #1
Powderdreams
Anderson, AL
Kubota 7040
Considering the purchase of a used (low hour) Kubota SVL 97-2 for personal property clearance with a mulching head. I have used local contractors a couple of times and due to the volume of mulching to be done and the current rates I can acquire a used unit at significantly less $$ than hiring out the mulching and own the equipment at the end. My concern is evaluating the used unit before agreeing to purchase. Track wear, leaks, maintenance log records (questionable as I know maintenance logs may or may not be accurate). Suggestions / input as to what should and can be checked - tested is appreciated.
KBH Tender (A63688)
KBH Tender (A63688)
Fork Extensions (A61572)
Fork Extensions...
Roll of Plastic Hose (A64119)
Roll of Plastic...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
Caterpillar Vibratory Compactor Parts and Service Manuals (A63117)
Caterpillar...
John Deere 8370R (A64119)
John Deere 8370R...
