Purchase advice
/ Purchase advice #1
8NTX
Rowlett, TX
Ford 8N, Ford 850
Hi Guys - I am new to this board and I have only been a tractor owner for about a year, but I have got the fever bad. Right now, I have an old Ford 8N and Ford 850 plus my lawn tractor, but I really do want a compact with FEL. My budget will be around $8,000, so I am sure a new one is pretty much out. I would like to have 25-30 HP. My place is 18 acres of woods, flat terrain, in East Texas (little snow). I will be brush hogging along the roads plus a few chores like moving dirt, pushing over saplings; ie. the regular stuff. I do have one moderately steep trail down to the lake that I need to drag some downed brush and wood out of, so stability is important. What would you recommend? I am sentimental about the old 8N and will probably keep her; please no wisecracks!/w3tcompact/icons/crazy.gif.
Thanks for your help.
/ Purchase advice #2
I'm sure our esteemed colleague, BIRD, is asking more then $8K...but you might want to talk to him. He's got a Kobuta B2710 for sale. This might be just what you need and want.
Here's the link: <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=genbuy&Number=121419&page=0&view=collapsed&sb=5&o=2&fpart=>http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=genbuy&Number=121419&page=0&view=collapsed&sb=5&o=2&fpart=</A>
/ Purchase advice #3
Yep, Bird wanted (and got) a little more than that, and the tractor left this morning./w3tcompact/icons/wink.gif/w3tcompact/icons/laugh.gif
/ Purchase advice #4
Bird,
Are you going through withdrawel symptoms yet ?
I hope it wasn't to painful parting with your Pride & Joy. Hopefully the new owner will take good care of it and allow you visitation rights. Maybe if he / she isn't a member already, we will see them join the TBN.
Bird, Best of luck with all your future plans. I hope to see your name here on the TBN for many years to come.
/ Purchase advice #5
for the chores and conditions you mention i think u most certainly must stay in the 24 to 30 hp range.no wisecracks about the 8n . when i bouth my b2400 i sold a ford 2n hated to do it but did not have the room to keep a tractor for sentimental reasons, +plus the $3500 i got for it helped to defay the cost of mynew(used tractor) you may want to consider doing the same?keep checking websites for used in your area and the paper also, or just drive around in rural areas , amazing what you will see out for sale.
/ Purchase advice #6
8ntx: forgot to mention!/w3tcompact/icons/blush.gif not familar with the geography of TEXAS but on the site where i found my tractor there is a dealer in LUBBOCK(?) that post quite a few tractors.the site is (hope this works) <A target="_blank" HREF=http://www.ironsolutions.com/>http://www.ironsolutions.com/</A> once u get there click on searsh or used and type in yur desires. .
/ Purchase advice #7
8NTX,
I understand wanting to keep the 8N for sentimental reasons, kept my 9N when we bought a TC40D. Haven't even fired it up in the past year. After having almost two years to wean myself I should probably just clean it up and then sell.../w3tcompact/icons/sad.gif
The 25-30 HP range will be more power then the 8N had but the frame on a unit with that HP will be smaller then the 8N. The smaller frame size will make it more challenging to move dirt, push saplings, etc, but you can it done with a little extra time.
Look to see what brands have good dealer support in your area and stick with those, the big three (NH, Kubota, JD) all have good machines. Many here on TBN also have had good experiences with some of the other brands but don't know much about them besides what I read here.
/ Purchase advice #8
8NTX-
You might try these sites...
http://www.fastline.com/
/ Purchase advice #10
Steve - I am only about 30 miles north of you and have similar needs. I bought a used JD 950, MFWD, PS, FEL, 2000 hrs for $8500 from a small dealer in Wylie. It has 27 hp PTO. I run a 6' rotary cutter and 5 1/2' box blade on it. I have started leveling a pad for a future pole barn. It does everything I need.
/ Purchase advice #11
Steve,
I also bought a used tractor from the Wylie dealer. They have quite a variety of tractors and have been there for some time. One interesting note - the dealer told me that any time I wanted to upgrade, he'd give me the full purchase price of this one as a trade-in on the "new" one. I guess he's assuming I won't destroy it in the meantime! /w3tcompact/icons/laugh.gif
/ Purchase advice #12
Greetings...
You may want to think about whether or not you NEED 4wd. With a FEL it's certainly nice, especially on hills, but if most of your property is flat you might be OK without it. I've got hilly terrane (Northern NY State) and picked up a Yanmar 336D (4wd, 33 engine hp, 27 pto HP, decent size frame (comparable to JD 1050 i think)) with FEL for just under 8500 (older sub-10k compacts are difficult to find in the Northeast US).
Good luck in your search,
Couchsachraga
/ Purchase advice #13
You are certainly correct that 4x4 is not needed for mowing or brush hogging relatively flat ground. When mowing, I only engage the MFWD when on the ditches along the road (quite a slope and I like the extra braking ability). I also use it when moving dirt with FEL or box blade.
ONAN 5000 GENSET EMERALD PLUS 50AMP (A64281)
ONAN 5000 GENSET...
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A59912)
2012 INTERNATIONAL...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
Striker Slide in Spreader Box (A62679)
Striker Slide in...
