PUMP for front end loader
/ PUMP for front end loader #1
KOREAN VET
Alvin,Texas
kubota L345 DT
HAS ANYONE TRIED TO USE A "PTO" PUMP TO OPERATED A FRONT END LOADER....I HAVE AN L345DT WITH A L1720 LOADER 1980 MODEL....THE ORG. FRONT PUMP HAS BEEN REPLACED SOOO MANY TIMES.....THE DRIVE SHAFT "SPLINE" IN GONE AND I HAVE TRIED MANY WAYS TO COUPLE THE PUMP TO THE ENGINE.... THOUGHT USING A "PTO" PUMP AT 1000 RPM MIGHT WORK.....OR ANY OTHER MODS.. THAT SOMEONE MIGHT HAVE TRIED AND GOT TO WORK......HELP.......
/ PUMP for front end loader #2
Are you just talking about putting done hydraulic pump on front ??? That's how most older tractors were done by. Yes you can
Oh and a heads up. You might want to get off the caps key. Some people will have your head for that
/ PUMP for front end loader #3
If a spline is getting chewed it's because 1 of 2 things, 1; something is not aligned or 2; lack of lubrication of the spline. Before mounting a pump on the front of the tractor you must ensure the pump you are fitting has the correct rotation and is speed rated for that application.
Hope this helps
/ PUMP for front end loader #4
Hope this helps
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A61573)
2017 Ford F-150...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
(4) 255/70R16 TIRES W/ (6) LUG WHEELS (A64281)
(4) 255/70R16...
2003 International 4300 Flatbed Dump (A62613)
2003 International...
