PUMP for front end loader
/ PUMP for front end loader #1
KOREAN VET
Alvin,Texas
kubota L345 DT
HAS ANYONE TRIED TO USE A "PTO" PUMP TO OPERATED A FRONT END LOADER....I HAVE AN L345DT WITH A L1720 LOADER 1980 MODEL....THE ORG. FRONT PUMP HAS BEEN REPLACED SOOO MANY TIMES.....THE DRIVE SHAFT "SPLINE" IN GONE AND I HAVE TRIED MANY WAYS TO COUPLE THE PUMP TO THE ENGINE.... THOUGHT USING A "PTO" PUMP AT 1000 RPM MIGHT WORK.....OR ANY OTHER MODS.. THAT SOMEONE MIGHT HAVE TRIED AND GOT TO WORK......HELP.......
/ PUMP for front end loader #2
Are you just talking about putting done hydraulic pump on front ??? That's how most older tractors were done by. Yes you can
Oh and a heads up. You might want to get off the caps key. Some people will have your head for that
/ PUMP for front end loader #3
If a spline is getting chewed it's because 1 of 2 things, 1; something is not aligned or 2; lack of lubrication of the spline. Before mounting a pump on the front of the tractor you must ensure the pump you are fitting has the correct rotation and is speed rated for that application.
Hope this helps
/ PUMP for front end loader #4
Hope this helps
6' X 20' TRI-AXLE GOOSENECK TRAILER (A64280)
6' X 20' TRI-AXLE...
2006 Mack CV713 Granite Tri-Axle Dump Truck (A61573)
2006 Mack CV713...
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
2005 Ford Explorer XLT 4x4 (A62613)
2005 Ford Explorer...
John Deere Pallet Forks (A66285)
John Deere Pallet...
