newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,882
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
Good - more data gum tree < 15" D(BH?) is on the small side.What I am trying to do is to direct the fall. I hook the rope to the tree and tractor and put tension on the line. I then cut a notch on the side of the tree in the direction that I want it to fall and then I make the relief cut so that the tree will fall over towards the tractor. Sometimes the tree will not fall and then I go get on the tractor and put it in reverse to apply enough force so that the tree will go ahead and fall.
I am talking about sweet gum trees probably 12-15 inches in diameter and 30 to 50 feet tall. He rope I am using is a arborist bull rope that is rate for 8000 lbs. I feel like I am safer being In
The tractor than I am standing under a tree that for whatever reason doesn't want to fall over. Sometimes you cut the notch and the felling cut and the tree just stands there. I don't want to cut through the hinge while trying to get the tree to fall. am I doing this wrong?.
Thanks
I cut down several 20" to 24" about 2 years ago. Had one split from the cut to about 15' up. They are mostly shelving on my pallet racks now.
Use at least enough rope/chain so when the tree is down you've got 10 extra feet.
With a NH 3930 you've got a fairly heavy tractor about the size of my M4700. If you've got enough weight in the back (so it doesn't lift when you pull) try and get the fastening device about 10 or so feet up the tree, the higher the better. DON'T put tension on the tree TOWARDS the fall direction where you are cutting the notch (https://www.osha.gov/SLTC/etools/logging/manual/felling/cuts/notches.html) wait until the notch is cut. I sometimes even give it a slight pull the other way, helps prevent the saw from getting stuck.
After the notch is cut put just a slight tension on the tree while you make the back cut. If your falling notch is half the tree (< 15" DBH) as soon as you are satisfied with what you have for a back cut you should be able to pull it over, even with a large hinge. Using wedges alone is maybe more "professional" but I've had to take down about 5 trees on my lots where there is a house, a fence, or some other structure where damage is a no no and tension on the tree helped ensure success and lessened the tension on me. And always be careful of interactions with other trees, especially if there are any vines involved.
