Ratio of weight on my tractor front to back.
   / Ratio of weight on my tractor front to back. #1
homedad
central/ se michigan
Kubota L3130DT
I have a Kubota l3130 DT with loaded R4s. With a set of Everything Attachments forks on the front and no implements on the rear does anyone know the Weight ditribution by %? I need to load it on my trailer with a log spltter near the tongue and can't get the tractor as far forward as usual. The rear wheels are behind the trailer axles. Although there is still positive weight on the ball of the truck I have no idea how much. I hate to have it swaying all over on the 3 hour trip. I'm thinking I need to put the tractor on backwards.
   / Ratio of weight on my tractor front to back. #2
Perhaps a photo would be helpful. That's a hard one to judge, or give hard numbers. Can you load the splitter on the tail of the trailer, and get the tractor forward? Short of that, you could pull it around locally and get a feel for how it's distributed. If it's going to walk, you'll find out pretty quickly.
I was feeling that having the splitter up against the front rail was more secure. I wish I had a scale to weigh the tongue either way. Just by way of the size of logs I can lift with no removable counterweight makes me think those filled tires are way heavy. It seems like 60% to 40% rear to front but never checked.
   / Ratio of weight on my tractor front to back. #4
I always back mine onto the trailer. That way, the wind turbulence at highway speeds won't blow the hood up and destroy it.
Also, with a cab on mine, I figure a rear window is cheaper to replace than a windshield if a rock gets kicked up and hits it.
Thanks. I guess I'll flip it around and see how it does.
   / Ratio of weight on my tractor front to back. #6
What do you suppose the trailer gross is with that load? Maybe 5-7k? I'm seeing from 10%-15% tongue weight recommended.
   / Ratio of weight on my tractor front to back. #7
You could do an experiment measuring the hitch height with a tapemeasure so your vehicle springs become a scale. You could climb up on the tongue to use your known body weight to calibrate it. Decide what tongue height indicates the right balance and then move things to achieve that.
i flipped it around and was so happy that I did. There was a bit of porpoising but not crazy. Normally I can center the tractor and it rides very smoothly. I could tell that when it was on facing forward there was more squat on the rear wheels of the trailer.
   / Ratio of weight on my tractor front to back. #9
I use a small hydraulic scale by Sherline to weigh the tongue. You could also read up on using a bathroom scale and some lumber.
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A60429)
2020 CATERPILLAR...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
UNUSED RAYTREE RMT48-48" HYD TRENCHER (A60432)
UNUSED RAYTREE...
bad boy zero turn 72 (A56859)
bad boy zero turn...
Crown RM6025-45 Stand-On Electric Forklift (A59228)
Crown RM6025-45...
