Pulling Tree Stumps Safely
/ Pulling Tree Stumps Safely #41
I was taught that to prevent the whipping action if/when a chain snaps one way is to put a blanket over it. We use an old army surplus blanket. I guess it is supposed to absorb some of the energy of the chain. Couldn't tell you if it works or not because I have never snapped a chain (knock on wood).
/ Pulling Tree Stumps Safely #42
Given the massive stored energy in a chain stretched to breaking, I would imagine that all an army blanket would do is provide you with a quarter inch of blanket between your head and a thirty pound mass of chain travelling at over a hundred miles an hour. :eek: No way a blanket would slow down or stop a lethal shot of chain.
/ Pulling Tree Stumps Safely #43
I just now remembered this, Mythbusters did a special on a cable breaking that was very extensive. There was nothing that could kill you. They were doing this with very heavy cable that I would be comfortable pulling on stumps with.
/ Pulling Tree Stumps Safely #44
I think the Mythbusters determined that it would not slice you in two. I saw that episode and I don't think they made any determination on lethality...at least in my opinion. Blunt trauma can kill you just as well as penetrating trauma.
What I don't remember was how they got the cable to its breaking point. It seems like they did it in a fairly continuous, steady fashion. Is that right? Or maybe they cut it. Anyway, I'd be more concerned about a breakage due to a sudden, violent shock load.
Regardless, I would not want to be hit by any of these options.
/ Pulling Tree Stumps Safely #45
At this point if the trees are already cut down, I would suggest that you dig around before removal. If that is not a solution you would like to pursue, then I would hire someone with a BIG dozer to finish the task.
By the way if you want to see sparks fly on a dead tree, we have one that is called Bois d'ark (pronounced bow dark, unsure of the spelling) in my area. in the days before t-posts, they were used. They would shrivel up and were tough as iron. I never saw anyone drive a steeple into them if repairing wire fence. They had to tie the wire up on the post. Sometimes it was called iron wood.
/ Pulling Tree Stumps Safely #46
I cut the tree 8 to 10 feet high. Wrap the chain (a long one) to the highest point you can reach. Pull it over with your tractor. I have removed quite large trees with this method. The long trunk gives you a huge lever. usually the whole stump and roots come up on the first try. If it doesn't try pulling it from the other side. After a few pulls from different angles you will find the wealk point.
On another point chains don't tend to strech and store energy. When they fail they yield and then break. Use a large enough chain.
/ Pulling Tree Stumps Safely #47
Are you sure that is correct? I know that marine chain is rated by several parameters and one of them is % stretch before failure. All that energy from pulling with 40hp or whatever your tractor puts out has to be stored somewhere if you are tugging away at a stump. The stump itself must have some of it but a sudden failure in the chain must release a fair amount back towards the source of the energy too (ie tractor).Any physicists, mechanical engineers or material scientists out there?
/ Pulling Tree Stumps Safely #48
AS a rule I love the Mythbuster program and find it very interesting. However on the cable breaking show I have a tendency to disagree with them. Anyone that spent time on a naval ship or other big ship can probably tell what a breaking cable looks like. There are plenty of documented case of what happens on an Aircraft carrier when a catapult cable breaks or an arresting cable.
/ Pulling Tree Stumps Safely #49
I believe the difference is in the way chains are made and cables made. I am no engineer but I have seen chains break and they jump then seem to fall down. Cables tighten to a smaller dimension before breaking and that seems to allow more stretch. Cables will whip pretty bad when they break. To see something really stretch watch a piece of nylon rope break especially the bigger stuff like 4 inch in diamater. It is similar to watching a rubber band snap
/ Pulling Tree Stumps Safely #50
One solution is to use chain that will NOT break, i.e. has a rating way beyond what your tractor can possibly put out - and do NOT jerk it.
Another is to thread rope through about every 4th or 5th link, tie it off to the tractor and to the load with an extra 2 or 3ft of slack at each end. More time and trouble than the army blanket, probably safer - as long as you use appropriate sized rope. I think this is more predictable, but still favor the chain that is so overspec'd that you will not break it without jerking - and just don't do that.
/ Pulling Tree Stumps Safely #51
There is elastic stretch and plastic stretch. Elastic stretch snaps back - plastic doesnt. All chains, and bolts for that matter, have initial elastic stretch that at some % gives way to yield - plastic stretch. All steel stretches elastically about the same, whether high or low stength. This means all steel has about the same stiffness. The difference comes in after the low stength steel begins to yield - it will no longer return to its original length when relaxed, whereas the hi strength will continue to stretch elastically. Perhaps it will stretch twice as far [taking twice as much force] before begining to yield. Twice the average force for twice the distance means it has 4x the stored energy. This energy surplus remains about the same as the two chains yield. When they break the low stength chain will be relatively well behaved in comparison to the hi. Standard logging chains are only moderate strength so they yield relatively easily and store less energy. Safer, but you pay for it by having to use larger chain to get the same strength. The energy surplus of the equal smaller chain of hi strength steel would then be 2xdistance and 1x force.... Twice the E.
larry
/ Pulling Tree Stumps Safely #52
jdgreg said:
Instead of pushing them over, I've found it's easier to pull them out of the ground, drag them to the burn pile, then use the grapple to pick the tree up and place it on the pile. I connect 2 tow chains together, the end at the tree has a slip hook. I cleared out a corner of a our property quite nicely like this. Largest tree was about 4-6" diameter, just make sure the slip is up 5-6' off the ground.
When pulling on trees, it should be obvious but remember you are under the falling side or the tree and if you miscalculate the height or the tree springs free toward you, you are likely to get a very bad headache. Some branches may be quite a lot longer than you invision.
Andy
/ Pulling Tree Stumps Safely #54
In my area, non coastal New England it is so rocky that digging with a front end loader is useless. Ther is no way that I would ever get a 24" oak out of the groudn with anything other than a backhoe and several hours or my excavator and a hour.
Andy
/ Pulling Tree Stumps Safely #55
larry
Thanks Larry, That makes a lot of sense and explains why chain may indeed be safer as psj12 suggested. It seems your explanation fit with Andy's experience if he was using Grade 70 chain which being high strength must have more elastic stretch. I've been using grade 70 chain under the perhaps false assumption that it was safer but it looks like a larger size of lower grade chain would actually be the safest for stump pulling.
/ Pulling Tree Stumps Safely #56
I work on the St. Lawrence Seaway and we require the ships to use wires for mooring. The wires (28mm) are a lot less likely to hurt somebody when they break due to the fact they don't whip very much at all. They make a lot of noise though and scare you pretty good!
/ Pulling Tree Stumps Safely #57
I use these wire ropes (aka slingchokers) all the time and have never had a problem. They are strong and very easy to get around a log(s). Everyone of my neighbor logger/skidder owners use these everyday in the forests around my home.
Bailey's - Pre-Made FSE Choker 1/2"x 14'
Pre-Made FSE Choker 1/2"x 14'(8 lbs)
/ Pulling Tree Stumps Safely #58
This is getting more confusing for me. The contradictions seem to be over whether 1) large but not high grade chain (so it breaks but doesn't stretch) or 2) wire rope is best. Why shouldn't polyester towing straps also join the contest for safest? Even if they break, they don't have much mass and assuming the broken side hook stays with the tree side, you would just have a nasty piece of pliable plastic webbing coming back at you rather than heavy steel. It might hurt like the dickens but is unlikely to take your head off.
What I get from this thread so far on chain/wire rope/straps is that one should clearly oversize them but additionally it seems there is a fairly wide range of products that are in use and considered safe. The other point seems to be that any of these can break but are most likely to break when applying a sudden rather than continuous force. The biggest risk then would be when you don't pretension the towing chain/wire/strap before applying towing force with a tractor. Again, the bottom line lesson to me is to get out the backhoe for stumps that are even close to a challenge rather than trying to yank them out.
/ Pulling Tree Stumps Safely #59
While in the Coast Guard we were given the standard Navy training on broken line recoil and were shown the movie of manaquins being taken apart by a line when it parts. The example shown was Nylon mooring lines that will elastic strech up to twice their length. Additionally catapult lines are being pulled by huge hydraulics that continue to pull after the line separates.
Wire rope much like chain is made of steel. It tends to yield some when breaking. I have seen several large wire ropes part and they do jump considerably but they don't recoil to the point of wraping themselves around the anchor points.
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
2024 MODASA  MH-25 I GENERATOR (A65643)
2024 MODASA MH-25...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
MIRRORS, MARKER LIGHTS, SWITCHES (A64276)
MIRRORS, MARKER...
Mayrath 10" x 34' Truck Auger (A66285)
Mayrath 10" x 34'...
2017 VERMEER TG7000 TUB GRINDER (A66091)
2017 VERMEER...
