SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,596
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
I know what your saying. There is no simple answer to which is best. All things considered tho, there is no contradiction. Here are a few back and forth points:IslandTractor said:[[[This is getting more confusing for me. The contradictions seem to be over whether 1) large but not high grade chain (so it breaks but doesn't stretch) or 2) wire rope is best. Why shouldn't polyester towing straps also join the contest for safest? Even if they break, they don't have much mass and assuming the broken side hook stays with the tree side, you would just have a nasty piece of pliable plastic webbing coming back at you rather than heavy steel.]]] It might hurt like the dickens but is unlikely to take your head off.
What I get from this thread so far on chain/wire rope/straps is that one should clearly oversize them but additionally it seems there is a fairly wide range of products that are in use and considered safe. The other point seems to be that any of these can break but are most likely to break when applying a sudden rather than continuous force. The biggest risk then would be when you don't pretension the towing chain/wire/strap before applying towing force with a tractor. Again, the bottom line lesson to me is to get out the backhoe for stumps that are even close to a challenge rather than trying to yank them out.
The stored energy thing is extremely important. You want to store as little as possible and not release it quickly. Compared to chain, rope and cable store a lot. However, the release of their stored energy is much more wasteful than chain. Visualize all those crisscrossed fibers rubbing against each other as the rope snaps back. Extend the same idea to cable - just not as much. Now, almost unique to cable, is the way it often breaks. Not sudden. Several strands followed by some give followed by more strands etc. Sort of pop pop pop instead of POW. The same energy is released, but a lot is absorbed/dissipated between pops. The speed of the rebound is another thing that sucks E out. Compared to chain, rope and cable are light. They move fast - - but they are moving thru air, and air is exponentially stubborn at speed. Not only must the air be forced out of the way of the recoil motion, it must also re enter between fibers where it was squeezed out by the tension - more losses. What about the form of the recoil? - a cable runs into its stiffness and has to loop around - a bad thing.
Contrast all this with chain.... Less elastic stretch even than cable but release is almost always more sudden. When a link fails some E goes into straightening it, but the force to straighten is comparatively small and the distance very short before the chain is free. There are almost no other unavoidable losses. Elastic recoil of steel is fairly efficient. External rubbing is almost nonexistant until the links slack. Nearly all of the [altho lesser] stored energy is now kinetic. The recoil is 10s of feet per second rather than 100s. But its massive and air isnt slowing it down. Zero speed is good speed to be hit by even a small part of a chain. If there is no recoil velocity off line of pull all is good. That wonderfully supple chain will come crashing into itself and form a puddle a couple feet behind your drawbar. A cable will not do this under any circumstance. If there is up velocity in the chain recoil you may be in trouble, but the likelihood of it reaching you with a chain is less than the others - its moving slow and so has plenty of fall time.
- What about comparative care and feeding, handling and storage, versatility in use? If its not chain dont ride it hard and put it away wet or dirty. Small fibers oxidize well and are also quickly compromised by abrasion. Dont think you will have freedom to change the working length at a whim or be able to suffer many physical abuses harmlessly that would kink or snap the others.
No way you can be totally safe. On the average tho, I think you are safer with chain.
larry
