Pulling a ratchet rake tooth....
/ Pulling a ratchet rake tooth.... #1
Buckgnarly
Platinum Member
West topsham VT
Kioti DS3510
So although my $99 RR fit my Kioti's 60" bucket OK, I could not stand having a tooth stick out of the bucket, so I pulled a tooth....
Fit problems: it worked, but lost the strenght of the outside tooth, prob never be a problem, but I can't let things go!
Plasma cutter had a workout!
No going back, tooth out!
Jig for welding....
First pass.....
Cleaned up welds....
Final fit...
Paint...
/ Pulling a ratchet rake tooth.... #2
And then there are those of us who will just have to wait for the little one to go on sale...
Nice work!!!
:thumbsup::thumbsup::thumbsup:
/ Pulling a ratchet rake tooth.... #4
:thumbsup:It's guys that can't let things go that get things done! Nice work!:thumbsup:
Nice job. Nice welding table too.
Thanks, without that it would have made muscling that thing around a whole lot harder!
Two observations, the RR is a GREAT well made piece of equipment, and the powdercoating on it was just as tough! I used the 9" grinder on the job, and the powdercoating stood up to it pretty well!
/ Pulling a ratchet rake tooth.... #7
Nice job. Nice plasma to cut 5/8" so clean. Nice TJ Rubi in the background. My fave is 05-06' unlimited rubi.
/ Pulling a ratchet rake tooth.... #8
Nicely done. Yes, I found the powdercoat to be tough too. Took a bit of grinding to get it off.
What size was the pipe you used to align the two pieces. I didn't think of that trick how did it work out?
I'm guessing you removed it before you welded it out so it would not get stuck if the piece pulled from welding.
It was 1" iirc, and yes I did pull it out, and yes it still pulled up! I made the mistake of doing the first top pass a little too long and hot, caused it to warp up a little. No way I would have gotten the pipe out without a fight, but it in no way affected the fit thankfully.
/ Pulling a ratchet rake tooth.... #10
How did you prep the joint? Beveled both sides or just one.
Double bevel with a 1/8" land would give roughly the sameamountt of
weld on each face. If you controlled your weld placement and welded out
evenly (until flush) on both sides then you could minimize or eliminate any
warp or pull.
Double bevel, but I should have taken it a little easier on the top. It's probably off by about 1/8 up, not a big deal just careless on my part!
/ Pulling a ratchet rake tooth.... #12
Nice work!!!
Don't wait!
I bought one.....and I think after using it for thirty minutes, it paid for itself from the wear and tear I already kit on my tractor NOT using one!
/ Pulling a ratchet rake tooth.... #13
kyles974 said:
Don't wait!
I believe u... R u going to post any pics of your cool tool and the work u did? What project did u use yours for?
/ Pulling a ratchet rake tooth.... #14
Don't wait!
Buy the 72" if you can find one and cut it down to the width you need. It will cost less even if you have to pay some one to weld it up for you.
POLARIS RANGER 1000 RTV (A62130)
POLARIS RANGER...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
208320 (A58375)
208320 (A58375)
6056 (A61165)
6056 (A61165)
