Narrow and shallow ditch digging advice please
   / Narrow and shallow ditch digging advice please #21
Hi All,
I am putting in a phone line from my shop to covered picnic area. The distance is about 80 feet. I don't want a deep or wide ditch because I want to disturb the ground as little as possible as it is all landscaped. So I want a ditch just wide enough to drop conduit into and only about a foot deep. I am thinking about welding up some sort of "tooth" and attaching this tooth to the front bucket on my YM2310. Then I can follow a line painted on the ground while going backwards. I want to use the front bucket because it has down pressure and I can force the tooth into the fairly hard ground. My other thought is to just lower one ripper from my box blade but that would probably take a few passes because the 3PH doesn't have down pressure. I will probably need to make a custom ripper that is long enough but I already have the steel and a nice plasma cutter. My ideas are probably not as good as the suggestions and ideas you all with more experience will have so please don't hesitate to let me know any better ways.
Thanks,
Eric
   / Narrow and shallow ditch digging advice please #22
Hi All,
Thanks,
Eric
I used a single bottom plow to run a wire from my house to the barn . It made a furrow . We laid on the wire and tipped the sod back over. Done. It was a horse drawn walking plow. If you can find a single bottom 3point plow with a coulter it would work even better.
   / Narrow and shallow ditch digging advice please #23
With the box blade and one tooth down, you will have the weight of the box blade. Don't forget that. I used to bury phone lines too, all day, six days a week. We didn't work Sunday because it inconvenienced people at their homes. But, if we had a mile long run across a farm, we'd be there doing it. I think the box blade apparatus will do the job, with a long tooth. They make a phone line, five pair that is shielded, has a metal wrap around the outside for direct burial. My brother is a phone man. If you catch a phone man you can ask him for a piece. They keep leftover pieces off large spools, rolled up at the phone office. They know how long they are. 5 pair shielded in conduit would be bullet proof, I dare say
Agree with this recommendation. If there’s no chance you’ll want to cross this line in the future, you’ll likely not need to encase the phone line in conduit. But if there’s a chance, put it in conduit and leave some slack on each end just in case you cross it and force a break.
   / Narrow and shallow ditch digging advice please #24
I might be a bit late to this party, but my wife and I pulled about 3 acres with of hidden fence through lawn, trails and general over growth. I made a cable plow for it that slipped on my back blade. It wasn't pretty (I didn't think it would work, but it did).
I used a 1" diameter piece of rebar that I had in the pile and welded two pieces of 6" long angle iron to it. One slid over the top edge of the back blade and the other under the bottom edge to hold it on the blade. I hacked a triangle piece out of some flat steel (like 3" x 3") and welded that to the bottom edge to act as a cutting edge on the front side. Last part was a piece of half inch conduit welded to the backside with a 90 degree bend at the bottom (I don't have a bender, so this was really ugly). I fed the wire down through the conduit, dropped the blade and drove. It worked awesome!! Cut through a lot of roots and left minimal disturbance. Essentially just walked behind stepping on the slightly heaved area and it practically disappeared.
What I thought was a single use tool got used again when I learned the thin yellow line doesn't last very long and we did the whole thing over again with better line. Worked even better that time since it wasn't as wet as the first time. In fact, it's probably still sitting in the scrap pile out back, waiting to be reused it repurposed.
   / Narrow and shallow ditch digging advice please #25
Hi All,
Thanks,
Eric
For all the fabbing and cobbling together of implements, I'd just go rent a chain trencher and be done. 80' will go fast, and if you run into rock or some impediment, you have an easier time with a trenches to redirect and circumvent. On the tractor it takes some space, clearance, and turning radii. Yes, $100 for 4 hours when it only takes 1 hour may seem expensive, but you are done. Good luck
   / Narrow and shallow ditch digging advice please #26
Try borrowing a ditcher from a landscaping or sprinkler installer, they are narrow and shallow, second try renting a burrower, utility companies use them to burrow from hole to hole without disturbing the ground to much. Was electrical contractor for 40 yrs.
   / Narrow and shallow ditch digging advice please #27
Hi All,
Thanks,
Eric
Yeats ago I used to install Dish Network cables direct bury using a 18" Puolan chainsaw with the chain turned backwards. Makes a small easy to drop in and easy to repair trench. That saw never cut any wood other than roots!!
   / Narrow and shallow ditch digging advice please #28
If there aren't rocks or roots this is fast and easy. You can use a quality flat shovel to do it.
   / Narrow and shallow ditch digging advice please #29
Hi All,
Thanks,
Eric
Running satellite dish wire, we would use shovel lift the grass up slide the wire just under the grass , as long as it's not in a garden spot , then water, can't tell the sod was ever distributed.
   / Narrow and shallow ditch digging advice please #30
I knew you all would come through! Tomorrow I measure and order but it looks like I'm gonna buy 150 feet direct burial CAT 6 for 32 bucks delivered. I will be using the slice and bury method. My son and I will be using spades to slice. Way better than digging or ripping. Almost no disturbance of the grass and a trail and it will heal in about a week. Thanks again for the ideas.
Cheers,
Eric
Where are you getting the cable?
I will likely be doing a similar project as I need to pull a line to my barn.
Amazon. Lots of choices. Avoid stuff called CCA, it is copper covered aluminum.
Eric
   / Narrow and shallow ditch digging advice please #32
Much as I like to use my tractor, an 80 foot ditch for a telephone line is at most a few hours work with a shovel. Probably much less.
   / Narrow and shallow ditch digging advice please #33
Tractor would create more work because of the rocks that would be unearthed in the process that would have to be picked up.
Maybe a manual lawn edger tool that you step on to press into the ground would be enough for this job.
My soil is too rocky for a shovel so a pick is needed. And my wrists are too arthritic for me to this job if I don't have to. Both wrists are bone on bone joints so I try to avoid stuff like pick work because it make them hurt too much.
Eric
   / Narrow and shallow ditch digging advice please #35
Would this be used to call someone and ask them to hurray up and read a text message you had sent ?
   / Narrow and shallow ditch digging advice please #36
Doesn't want to miss any telemarketer calls.
   / Narrow and shallow ditch digging advice please #37
Eric
I wonder how many of us pay a local handyman help for little jobs like this? I do quite often. In fact, I keep a list of this type of job that need doing around the property and consult it when the handyman comes around looking for work.
Thought I'd update the shallow ditch. First of all it turns out that I'm not a very good estimator of length. The 80 foot ditch is actually 105 feet long. This must be why my wife is always wrong when it comes to how long something is. 'AHEM' .
Anyway, what I ended up doing was to use a ripper hanging down as far as possible from my box blade to rough in the ditch. Then I used a new pick mattock to finish the ditch to depth. The reason for the new tool is because it is considerably lighter than my old pick mattock which makes it easier on my wrists and hands. Nevertheless I am still waking up in the middle of the night from considerable pain.
So, after burying the phone cable I packed the dirt in as much as possible. To help with that I borrowed one of those vibratory compactors from a friend. I moistened the dirt to help with the compaction and consolidation of the dirt. As is always the case for me I never have enough dirt to fill in the ditch I just dug so I brought in some extra dirt from a pile I have just for that purpose. That vibratory compactor is a great machine. It really does a great job.
The direct burial wire ended up about 8 inches deep. Yeah, I know, it should probably be deeper to comply with code or good sense or whatever. But it is a low voltage, low current, low data cable. And I'm a low brow person. And it is my property after all, and the only threat to the cable is the lawn mower. And if my lawn mower starts to mow 8 inches below ground level then I have other problems that really need addressing.
After I compacted the earth it looks great. And next year when the grass has re-grown over the injured area it will be invisible.
The best part of this ditch digging is how it all ended up, phone wise. I called Whidbey Telecom technical support to find out if their system still supported pulse dialing. The answer was no, it did not. I was going to buy a pulse to tone adapter but forgot. After the wire was in the ground and everything was done but the connecting of wires I did just that. I got a dial tone. Yay! So then I tried dialing the old rotary phone and Whidbey Telecom does still accept pulse dialing, despite what the tech support guy said. Cool!
Later,
Eric
   / Narrow and shallow ditch digging advice please #39
Several people have asked why we have an old style dial phone on the kitchen table.
It's because we live rurally and get a lot of power outages. When power stops, all the data/phone lines that rely on power go down too. It doesn't help to have power at the house if the relay station up on the mountain top is not getting power.
But the old dial-type phone lines still work. Unplug the new phone and plug in the old. Now you can talk to neighbors and emergency messages still work.
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-250...
Nissan Forklift (A55973)
Nissan Forklift...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
