PTO water pump
/ PTO water pump #21
holy cow. why are so many people afraid to put hours on their tractors. i used to irrigate fields in montana with tractor mounted water pumps. they ran for days at a time. these tractors WERE 20 YEARS OLD AND RAN STRONG. Todays modern units can take it.
i hear the same thing said about log splitters..... like there afraid to let a tractor run.
/ PTO water pump #22
Meanwhile, farmers in Holland let their $400,000+ tractors sit for weeks straight pumping out water during flood season.
/ PTO water pump #23
I'm surprised people have so much trouble with small engines.
I have a number of machines with crappy small engines which I use at most once or twice a year (particularly my walk-behind tiller since I got a tiller for the tractor), and I haven't had one fail to start within three pulls of a cord - ever.
I always turn off the fuel valve and run the engine dry before putting it away.
California, 10% ethanol gas, no stabilizer. Am I just lucky?
Seems to me if you just need to use the pump once a year, either buy one and sell it right away, use it for target practice, or just rent one.
I have a good income but I definitely can't convince myself to spend $2-3k on an almost-never-used device....
/ PTO water pump #24
I don't need another engine just to run 3 or 4 days a year.
Something else that won't crank when needed!
/ PTO water pump #25
i understand, but i have several portable generators i used to use in the field before i retired as an electrician. if properly stored, they will always work. my briggs 8kw hasnt run in several years, but i used it a few months back and started in a few pulls. not that hard if prepped correctly. my wifes mantis runs 1 day a year. always works. plus, i only use non ethanol fuel.
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2018 Kubota B2301 (A60462)
2018 Kubota B2301...
Iranch IRET13 (A60463)
2012 Freightliner Cascadia (A61307)
2012 Freightliner...
1010 (A61165)
1010 (A61165)
