pto stubs
/ pto stubs #1
hounder
what options are available for stub extensions to make room for a hydraulic pump but still have the option of connecting another pto driven implement? example permanently mount pump and then have the ability to connect posthole digger as well
/ pto stubs #2
Agri-Supply and TSC sell extensions, but you will need to make sure you have enough stub left after the pump is placed over the shaft.
PTO ADAPTER 1-3/8X6SPL M. X 1-3/8X6SPL F - Agri Supply
/ pto stubs #3
I'll bite... why do you need a pump and posthole digger at the same time???
I have a pump on the end of a shaft that turns a blower, but it's at the end of the line, sort of speak. I have another pump that lets the end of the pto stub hang out but not enough to lock the pto shaft on. You might be able to bolt onto it... but the one shown above, uses the whole pto shaft, just extends it.
You could use an electric pump or rig up a hydraulic pump (not even sure they make one but sounds good.)
/ pto stubs #4
I've seen as long as 7" extenders at tsc..
soundguy
/ pto stubs
the issue is I don't have enough volume or pressure with my current pump to run everything I need to and don't really have any options other then using a pto driven pump. however i can envision the difficulties of attaching and removing the pump all the time. I don't care to go that route unless there is absolutely no option
/ pto stubs #6
I DID see a long shaft extender at TSC today.. havn't seen them in a while.. but they are apparently still carrying them.
soundguy
/ pto stubs #7
How much HP does your tractor have? It will take a couple HP per gpm flow to run the pump at full working pressure.
larry
/ pto stubs #8
Give us some more info to work with...what tractor?
/ pto stubs
its a case 830 diesel the tested hp is around 60 with a bit more at the draw bar.
/ pto stubs #10
OK. You can do about 20 GPM at the PTO and still have enuf left over to move the tractor pretty well.:thumbsup: Youll need a pretty big reservoir to keep temp down.
larry
/ pto stubs
is a twenty gallon tank enough?
/ pto stubs #12
The "general" rule of thumb is 1 gallon in the tank per 1 gallon pump output, so if you have a 2GPM pump, you want a 20 gallon tank.
2015 LeeBoy 8510C Asphalt Paver (A64553)
2015 LeeBoy 8510C...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
KUBOTA TE6583T - 6 BASKET HAY TEDDER (A64278)
KUBOTA TE6583T - 6...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2022 JOHN DEERE 17G EXCAVATOR (A63276)
2022 JOHN DEERE...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
