PTO shaft ?
/ PTO shaft ? #1
EMS503
Harmony, NC
1960 or 61 MF35 Deluxe, 2008 Kubota L3940 GST
Hi I just traded my MF GC2300 in on a L3490. I have a fertilizer spreader for spreading salt in the chicken houses and lawn fertilizer, I had to have the PTO shaft cut down to fit the MF now when I hooked up with the Kubota I have about 4-5" before the shaft seperates when the spreader is sitiing level. And it seperates when I place it on the ground. Will this shaft be safe to use or should I get a longer PTO shaft? Just want to be safe.
Thanks
/ PTO shaft ? #4
Possibly consider a slip clutch like this one
SLIP CLUTCH W/1-3/8X6 MALE X 1-3/8X6 - Agri Supply
I just had to shorten mine due to the clutch I just bought.Sounds like the adapter is the cheapest way to go, but if you were to spend more for a new shaft, you might as well spend the 82 dollars and get the benefit of the clutch also
/ PTO shaft ? #6
Slip clutch is a waste of money on a spreader. Probably not enough room for one anyway. But one of those 4" extensions is a good idea - I should have thought of that. Especially since I've actually got one on my KM454. I bought it to compensate for the extra 4" separation added by the PEC hitches.
//greg//
/ PTO shaft ? #7
I'd go with an extension. I wouldn't worry about the short overlap when running (it's only a spreader), but it beats the heck out of trying to remember to never drop the spreader with the pto running. Whack whack whack whack whack whack whack....
Lone Star dump trailer (A55973)
Lone Star dump...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2020 Broyhill Load and Pack TD3.6 Mini Articulated Garbage Truck (A59230)
2020 Broyhill Load...
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2017 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A59230)
2017 GMC Sierra...
