Pto problem...
/ Pto problem... #1
Revron
John Deere 4500
Jd 4500::while using bushhog when I get in thick grass such as the road grass I call it, pto stops...shaft and all.. the manual says not enough rpm on tractor..give more rpm..what do y’all think?
/ Pto problem... #3
That does not sound correct to me. If the engine stays running but PTO stops, something is slipping.
/ Pto problem...
Thank you...my thoughts exactly..thanks
/ Pto problem... #7
Sounds like either low pressure or a worn out clutch. You can check the pressure with a 300 psi gauge and a 1/8" male pipe adapter. Pressure should be around 218 psi. If low, you can check orings on solenoid, or possibly defective solenoid. If solenoid and orings are good, then cliutch needs to come out and rebuilt. If pressure is good, then clutch needs rebuilding for sure.
New/Unused IRGC40 Mini Golf Cart (A65583)
New/Unused IRGC40...
2025 Swict 84in. Bucket Skid Steer Attachment (A64553)
2025 Swict 84in...
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
2016 Ford Explorer (A66408)
2016 Ford Explorer...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
