Pto problem...
/ Pto problem... #1
Revron
John Deere 4500
Jd 4500::while using bushhog when I get in thick grass such as the road grass I call it, pto stops...shaft and all.. the manual says not enough rpm on tractor..give more rpm..what do y’all think?
/ Pto problem... #3
That does not sound correct to me. If the engine stays running but PTO stops, something is slipping.
/ Pto problem...
Thank you...my thoughts exactly..thanks
/ Pto problem... #7
Sounds like either low pressure or a worn out clutch. You can check the pressure with a 300 psi gauge and a 1/8" male pipe adapter. Pressure should be around 218 psi. If low, you can check orings on solenoid, or possibly defective solenoid. If solenoid and orings are good, then cliutch needs to come out and rebuilt. If pressure is good, then clutch needs rebuilding for sure.
JOHN DEERE 5085E TRACTOR (A64277)
JOHN DEERE 5085E...
2012 MACLTT  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2012 MACLTT 150...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
2021 TAKEUCHI TL6R SKID STEER (A65053)
2021 TAKEUCHI TL6R...
Cub Cadet 5252E Riding Mower (A65579)
Cub Cadet 5252E...
John Deere 316 Riding Mower (A66408)
John Deere 316...
