Pto problem...
/ Pto problem... #1
Revron
John Deere 4500
Jd 4500::while using bushhog when I get in thick grass such as the road grass I call it, pto stops...shaft and all.. the manual says not enough rpm on tractor..give more rpm..what do y’all think?
/ Pto problem... #3
That does not sound correct to me. If the engine stays running but PTO stops, something is slipping.
/ Pto problem...
Thank you...my thoughts exactly..thanks
/ Pto problem... #7
Sounds like either low pressure or a worn out clutch. You can check the pressure with a 300 psi gauge and a 1/8" male pipe adapter. Pressure should be around 218 psi. If low, you can check orings on solenoid, or possibly defective solenoid. If solenoid and orings are good, then cliutch needs to come out and rebuilt. If pressure is good, then clutch needs rebuilding for sure.
2018 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 PETERBILT 579...
2015 Polaris Slingshot Motorcycle, VIN # 57XAASFAXF5104933 (A65563)
2015 Polaris...
2014 FREIGHTLINER CASCADIA,TANDEM AXLE 6X4 SLEEPER TRACTOR (A59914)
2014 FREIGHTLINER...
215603 (A63276)
215603 (A63276)
2020 International HX620 Quint Dump (A62613)
2020 International...
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
