Pto problem...
/ Pto problem... #1
Revron
John Deere 4500
Jd 4500::while using bushhog when I get in thick grass such as the road grass I call it, pto stops...shaft and all.. the manual says not enough rpm on tractor..give more rpm..what do y’all think?
/ Pto problem... #3
That does not sound correct to me. If the engine stays running but PTO stops, something is slipping.
/ Pto problem...
Thank you...my thoughts exactly..thanks
/ Pto problem... #7
Sounds like either low pressure or a worn out clutch. You can check the pressure with a 300 psi gauge and a 1/8" male pipe adapter. Pressure should be around 218 psi. If low, you can check orings on solenoid, or possibly defective solenoid. If solenoid and orings are good, then cliutch needs to come out and rebuilt. If pressure is good, then clutch needs rebuilding for sure.
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
2022 EZ-GO ELITE...
John Deere 1010 Cultivator (A66408)
John Deere 1010...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
