PTO Generator
/ PTO Generator #21
@Robin Veerman
I'm not sure why some generator manufacturers design pto generators to run at 510 rpm's, if that's your question.
As far as what difference it makes... not much. By specs, my tractor engine rpm's are 2476 at 540 pto speed, and 2338 engine rpm's at 510 pto speed.
/ PTO Generator #22
I have had several occasions where the PTO generator came in quite handy. Ice storms taking out power, summertime wind storms causing power outages and now and then I use it for remote power. I found a used WinPower generator for my son a few months ago.
/ PTO Generator #23
We live in an area where we get a lot of weather and probably lose power at least once a month and often several times. The problem with PTO generators is simple - when you need a generator is right when you also need the tractor.
After trying a PTO generator we switched to Honda and Generac stand alone generators. The two together use less fuel & maintenance than a tractor. One runs on gasoline and the other on propane. Nice to have both. That leaves the tractor for dealing with debris.
rScotty
/ PTO Generator #25
rScotty
That keeps being repeated over and over, but in all the years I've had a pto generator it's not happened to me, even one time.
I can honestly say, I've never needed any tractor, when I had my tractor running my pto generator.
SR
/ PTO Generator #26
SR
I'm thinking the same way. I have two small Honda generators, but the issues involving gas fuel storage, ethanol issues and I already have a diesel tractor. I feel it's another job that can easily be done with the tractor. Many storms cause damage to trees and buildings etc, but the need to have the tractor available for cleanup has never been urgent, while the need for electricity was. My quest for a quality and reasonably priced pto generator is ongoing. I'm impressed with the Baumalight QC generator specs (12kw is my goal), and Winco or Winpower (same company?) units seem quite popular too...
/ PTO Generator #27
What’s the difference for 510 rpm vs 540 rpm that some generators have on their specs?
What's more important than this is the cycles. You want 60 cycles per second which you adjust with the engine rpm. If that spec ends up being a little below or above the rated pto rpm it doesn't matter much.
/ PTO Generator #28
I also have two small Honda generators which work well for lights refrigeration, etc. For well pump, cooking appliances and A/C, I use the Baumalight 12K trailer mounted PTO generator. I find the trailer genny is quicker to hook up than a 3pt mounted unit.
I have a second tractor but have yet to need it during the outages we get around here. Unless the road gets blocked, clean up can usually wait until power is restored.
My main concern is the fuel supply. Gas stations can't pump during an extended widespread outage. Unless you have a huge propane tank, you can easily run out if the power is off for a week or more. I keep my 1000 gal fuel oil tank topped off during the stormy season and it will run the tractor PTO genny several hours a day for at least month if necessary.
/ PTO Generator #29
rScotty
I don't think I have to worry about needing a tractor and running the generator at the same time. Tractors are reliable, now the problem with little piss ant generators is that they are powered by single cylinder air cooled gasoline engines that were invented in hell and brought to us at the hands of the devil! Give me diesel or give me death...didn't some American patriot say that!
/ PTO Generator #30
The two times of the year when I lose power are during ice storms, and Spring Thunder Storms. It's hit or miss if it happens, and most of the time, power is back on fairly quickly. For 99% of the time, my little Honda generator is all we need to keep the lights on, watch TV and charge our cell phones.
Since the power loss is so unpredictable, I would have to disconnect what's on my tractor to hook up a PTO Generator. I hate removing what I have already hooked up to my tractor because that's what I'm needing on it. I would hate it even more if I did this before a storm and we didn't lose power, or if I waited and I had to do it out in the weather during a thunder storm. I can't think of a good time to hook up a PTO Generator.
The little Honda cost a grand, it starts every time, it's easy to bring out to where I'm working and have electricity for my tools without using a tractor that might be needed for something else.
If I was to buy a bigger generator, it would be a Natural Gas generator that would be mounted in my garage. Last year we lost power for 5 days from a snow storm. The Honda and wood stove kept us comfortable, but it would have been more comfortable with more power. Not a priority, but something to plan for down the road if a deal comes along, or our power supply continues to fall apart.
/ PTO Generator #32
I might run the tractor for a generator too if our power outages were due to storms. But the last several have been due to forest fires and before that floods. So we need the big tractor free to be used. That's why we keep a hundred HP tractor fueled and ready to use.
On 510 vs 540 RPM question.... Voltage output goes down in proportional to the square of the decrease in RPM. That's reasonable for resistance heaters and not so good for computers, lights or TV.
The drop in frequency is less than the drop in voltage. Frequency is just a regular linear thing. i.e. drop the RPM in half and the frequency drops in half as well. But the problem is that it is the 60 cycle frequency is important to keep constant for some computer circuits. And nowadays even the coffee pot has a computer chip.
Best to just run it at the rated speed if you can.
rScotty
/ PTO Generator #34
Actually, at the advertised RPM it produces the correct frequency (60 cycle). The voltage is secondary.
If it's a self-energized field coil type of generator it can't maintain both voltage and frequency at a lower RPM. It has to choose one or the other. .
Simpler to just run it at rated RPM.
/ PTO Generator #35
I understand the comments above. But I was wondering why most generators are 540 rpm while some others are 510 rpm. I’m thinking that the main benefit is better fuel economy with a 510 unit…🤷
/ PTO Generator #36
I've wondered the same thing. A generator can be built to operate at any RPM. And then if it's run at any other RPM we know what the trade-offs are. But why 540 rpm for PTOs anyway?
Does anyone know why 540 rpm became standard for PTOs in the first place? It seems an unusual number...
/ PTO Generator #37
When the power is out (very seldom) I can get by with a Honda portable gen and it gives good clean power that won’t heck up my TV and computers, and sips fuel in economy mode. And the Honda gen can go camping, tailgating, RV’ing. The other benefit is that the tractor is free to push snow or tree limbs or do other chores, and I don’t want to put 24, 48 or 72 hours on the tractor meter just to keep lights on and the refrigerator running.
/ PTO Generator #38
From google…. 540 was the early standard primarily because it was the speed of the intermediate shaft in the Ford 9N, 2N, and 8N transmission at the engine speed for near maximum engine power. That PTO was very simple inside the tractor, and is just an extension of the transmission intermediate shaft.
/ PTO Generator #39
I would imagine it's because 540 has been the standard for most small/midsize tractors since...forever? 510 may be a way to get some fuel efficiencies as some tractors have more than enough PTO HP to run a generator so the power band at 510 is sufficient to generate the required kw(s)? Pure guess on my part. If I was trying to generate 10 KW for my house that's ~14 HP so waste a lot running my MX with ~50 PTO HP at 540 RPM, probably be more efficient to run my larger tractor at 540e and much more to run the larger 540e at 510 I bet while still generating plenty of PTO HP. Assuming as mentioned all the output specs still work.
ETA you're probably not running a standard 540 at exactly 540 on your tractor's TACH either if you're measuring the output of the generator, probably close but you should be measuring the output from the generator not the tractor PTO RPM.
/ PTO Generator #40
Your basic 2 pole generator needs to turn at 3600 RPM to produce 60 cycle power. To get from 540 or 510 to 3600 just requires different internal gears to obtain the required RPM. Maybe one set of gears is cheaper than the other. Who knows..
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A69167)
2014 INTERNATIONAL...
2013 ELECTRO-STEAM INDUSTRIAL PRESSURE WASHER (A65054)
2013 ELECTRO-STEAM...
2013 WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
2004 POLAR TANK CRUDE PUP TRAILER (A67714)
2004 POLAR TANK...
CAT 966G Grapple (A68134)
CAT 966G Grapple...
HANDICAP PORTA POTTY (A67714)
HANDICAP PORTA...
