Generator pto generator
/ pto generator #41
So your 27kw can be had for 2549$ + $6000 for the 54+hp tractor...so you are about $8549 for the combination versus guardian standby steel/aluminum case 25kw 9300$
Close to even...and with the stand-alone...you have your tractor available to handle all those trees that will be knocked down by the storm that knocked out your power...;)
In that example.. i like the tractor and pto gen much better.....After all.. I can't hop on the guardian standby generator and disconnect it from the house and go move trees!
( Besides.. if i need trees moved.. I'll hop on one of my 3 loader equipped tractors and go at it.. or if they are bigguns'.. I'll hop on my 95hp tractor and start dragging them while the 70hp jobs keeps the lights on... ;) )
soundguy
/ pto generator #42
I agree with the fact of having another motor around to maintain being a pain. I like even better having the tractor freed up to take care of tree's or clean up after a storm. My Dad is 80 and my Mom and Stepdad live next door to him. If the power goes out I have to make sure they are ok. Right now I have 2 generators. A 5KW unit and a 8.5 KW unit. That will keep both of them powered up for as long as we have gas. The 8.5 KW unit I picked up at this auction site brand new with Electric start on wheels for $500. Right now if you look at their site they have a 25 KW on trailer and a 50 KW Generator being auctioned. We aren't allowed to put links on here so do a Search for Bidadoo auctions and look at some of the toys they have. PS this isn't a paid advertisement as I am not associated with them at all.
/ pto generator #43
I take it this place is on E-Bad? ;)
soundguy
/ pto generator #45
soundguy
Okay...so you'd say...
"Friends don't let friends own just one tractor"...:D
/ pto generator #46
I think we only need about a 12kw pto generator but have a larger tractor(105 kubota)Is it necessary to crank the diesel all the way up to turn the pto at 540.With that much HP wouldn't I waste fuel plus wear at higher engine RPM?Is there a way to run the engine at about 1800 & still generate 12KW?
/ pto generator #47
You can Gen 12KW at a slower speed it just won't be 60 Hz which will cause all kinds of problems to motors and other frequency sensitive equip.
If the gen to designed to run at 540 to produce 60 Hz current then you MUST run it at 540 no matter what the load (kw).
/ pto generator #48
Thanks for the info. I may consider a small diesel gen.
/ pto generator #49
As another poster said.. you need to run the pto gen at the rated pto speed for it to make the correct frequency power.
Your machine is made to run at it's rated pto rpm
Waste fuel? For the most part, fuel usage is based on load.
For instance.. I have a 70hp and a 95hp diesel tractor.. I have cut my pasture with both of them using a 10' mower.. the 70hp tractor uses 5g of diesels to cut the pasture. Guess what.. so does the 95 hp tractor! What does that tell us? It tells us that just because a tractor can make 'X' power doesn't mean it always is.. fuel is used based on the power requirement of the job. You may geat small differences based on machine size and weight if one machine weighs alot mor ethan another as that will be 'overhead'.. but the actual fuel consumed to power generated ratio should be pretty close.
soundguy
/ pto generator #50
You might want to peruse this before buying a PTO Generator...
Tractor-Driven Generators: Producing Quality Power
Massively Excellent Post
I nominate you for Generator General! Here, the Virgin Islands, the home of power outages, these issues are huge. Years ago with simple electronics, mule powered generators were probably ok. Now, with circuit boards on everything including gas stoves, trash power will be your downfall. A quality gasoline powered genset, between 5 and 15kw will provide clean, safe and relatively economical power.
I can't afford a 15/20kw diesel genset but get by quite nicely with a 7.5kw gasoline (Honda) powered unit connected by transfer switch which limits circuits energized to those most necessary, and within the output capability.
While I would love to have an 1800 rpm genset humming quietly, the 3600rpm Honda 13 HP (Porter Cable Branded) keeps me going and has the onboard controls to deliver relatively clean power. I am able to run Sat TV, computers, water pump, lights, etc. without damage. EVERYTHING delicate here is on at least a surge protector courtesy of our municipal (variable voltage/cycle) provider.
We have at least four outages per week and this doesn't include over/under voltage episodes and one can only guess at the htz!
The only source worse than Virgin Island Water and Power Authority would be a tractor at variable rpms driving a genset with unknown controls pumping electrons into all your equipments. (Mule/Ox Power). In addition to extended Hurricane outages, we have "rotating outages" where the municipal capacity cannot serve the entire feeder load and "unexpected outages" that occur, "just because".
Conclusion: Buy a generator/driver combination unless your needs are grounded in 1955.
Comment: Children in the Virgin Islands learn how to use a flashlight before they learn how to walk.
XO
tomas
/ pto generator #51
you guys crack me up.
ever look at the head on a pto gen.. then the head on a portable.. now think about how the big boys make power. it's all pretty much coaxing electrons off a ball of copper.
that ptogenset or portable will be cleaner power than from MOST DC inverters.
as long as you can keep rpm governed, you should be good to go. keeping the rpm governed will be a function of load, hp, rotational mass and the capabilities of the governor and engine.
an endurance test with my 12.5kw gen set running behind one of my gasser antiques into a graphing meter with history, showed my pto genset held better frew and voltage regulation than my own utility grid did, using a variety of restive, and inductive loads, including sensitive electronics.
what was surprising was not only was there better voltage regulation.. IE.. less peaks and dips.. but the freq from the utility was always bouncing around +/- 1 or so... perhaps alot of power factor correction going on on the grid?
soundguy
soundguy
/ pto generator #52
*Me neither.
DIDO, I struggle enough finding the time to swap hoe, for boxblade for tiller for york rake, would hate to be dropping a hoe and hooking up a genset in a storm. Much easier to role the gas generator out the garage door, start her up and plug her in.
Joel
/ pto generator #53
that just means you don't have enough tractors ;)
soundguy
/ pto generator #54
I have a 35hp tractor and a 50kw Winpower alternator. I even run A/C as necessary. It has 540 rpm pto input and I've bought a photo tachometer to check the rpm and a frequency meter to cross check it.
That being said, I then bought a reducer gearbox from Central Georgia Generator for $299 that I connect to my 1500 rpm 3 cyl diesel lawn mower's pto (which normally runs a mower deck). The gearbox has a standard farm type splined pto output shaft which I connect the Winpower too. I set the F935's throttle to produce 60Hz. at the 115v electrical plug and I am in business. This frees up the tractor for clearing the giant sized hailstones, downed windmills, overturned minicars, lost city folks, smashed pumpkins, snowflake collectons, and those pesky trash containers that get balled up in the tinsel and barbed wire residue. I'm sure you city folks are lost at this point.
THe F935 has 2 6 gal fuel tanks, while the tractor only has a 10 gallon tank, so I'm way ahead on lighted bathroom reading and comfort time with the mower conversion deal. All I need to do is put the bolt-on bracket with the gearbox onto the left front mower lift arm, swap the pto shaft to the gearbox input and hook on the alternator (which is rigged with a hitch and trailer axle). Then its just a matter of locating the 220v extension cord. This can be touchy when its pitch black dark outside, the full moon is a week or 2 late, and the raindrops are so big they can hurt you.
Plus, now I can take the welder, Power Painter and electric pressure washer on field trips that all you stationary guys only can dream about.
/ pto generator #55
that's one thing I like about my pto genset. i put it on a 3pt caryall platform that has enough space to set my hobart ac buzzbox on.. :)
soundguy
/ pto generator #56
I have a 12.5KW generator mounted on a small trailer that I use with my Mahindra 2516. Works great for me ;)
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
We do NOT accept credit cards as payment. (A64126)
We do NOT accept...
Landhonor Quick Attach Power Rake (A66285)
Landhonor Quick...
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
