Generator PTO generator feedback
/ PTO generator feedback #131
Well, generally speaking, well pumps are not positive displacement.
From what I know and my experiences, the amps are dependent upon the flow, not the pressure. Dead-heading the pump will result in the least amount of amps, unless the bearings in the motor are bad, in which case the amps will go up. That is how I used to check for bad bearings in a submersible motor. Dead-head the pump for a short period and see if the amps drop. If the amps go up, the motor needs replaced.
My fluid dynamics class of course covered a lot more topics, but it's kind of foggy after 10+ years. Enlighten me on the answer.
I work on pumps, motors and electrical equipment. Much to my surprise I discovered some larger motor/pumps(that would be in the centrifugal category) actually go up in amps as they approach cut off head. I have only run into a few and I was doing pump wire to water efficiency testing when the results showed amps rising when I thought they should be falling as we reduced flow. I thought no that cant be and researched it and they are the exception to the rule. So for the 99.9% of the pumps out there your statement is correct. I can look up the info if your interested. I included the info for details sake because when I work on equipment I like all of the details.
/ PTO generator feedback #132
The MF example I am citing is a HST tractor, not a gear tractor. Power transfer from engine to PTO is not a "straight shot out" as you state. As you suggested in your earlier post, engine to PTO losses are significant in a HST tranny. I am not making up the loss data. It is FACT based on published data. Not my data. Not my gut feeling. Published data from the manufacturer I take to be factual. Nothing quizzical about FACTUAL data.
I was not disputing your quoted tractor loss, only calling attention to the need to take a harder look at the gear data because of the extreme difference between 14% tractor loss and the loss quoted for a gearset.
Please refer to my cited references. Reduction ratio is irrelevant to efficiency. Gearset efficiency is determined foremost on tooth interaction. Tooth interaction is based on tooth design. While all gear teeth make look similar, there is a large variation in design, efficiency and cost of manufacture. I'm speaking to differences in tooth design (profile) of straight cut gears. (Not between one gear types and another) Lubrication also is vital. Hardness is also important. If you refer to the references, the efficiency numbers assume gearset operating in a 90W gear oil bath.
I see nothing in Marks regarding relevance of ratio. Handbooks often cleave to average or accepted type of application and do not delve into special cases where the envelope is pushed a bit too far. "Who would think of a 7 to 1 increase! ... and your expecting that efficiency? Sorry, forgot to tell ya...." Another thing unreported by the handbook is the actual way in which the test they get information from was conducted... Was it a dynamic test of the whole gear on gear system or was it a static test measuring torque in / torque out x ratio, designed to measure only the loss inherent in the lubricated gearmesh. If dynamic, what bearings, what rpm? If done at high rpm, what are the particulars of the "oil bath"? In your zeal to contradict you are placing too much emphasis on information that is not complete. Im hoping neither source actually said that ratio is not a factor unless they qualified the range in which it was not. Any handbook of mine that made such an unqualified statement would get a notation to alert the reader to investigate further.
Please understand, these references are not some theoretical calculation from some math professor. The references are engineering design handbooks.
Do you think the handbooks do the tests themselves? Gear on gear efficiency is very high for spur/ straight cut gears, and the math professor would show you why. It is the fact of very little sliding as the teeth mesh and "roll" thru the contact arc. Some sliding does occur however as a result of the distortions of loading. The math can factor these out and phase them back in easily on paper. Certain test design can do this in a system to quantize the losses of specific parts. We know nothing about the design of the test the data is quoted from.
This statement is irrelevant. The cited efficiencies are based on gearset in oil bath.
Again, is the gearset running in an oilbath and system input/output compared... or been run in an oilbath til in broke in and then measured statically. If its a dynamic test define the oilbath. How deep are the gears in the oil. What rpm? The statement about light oiling is appropriate in the dynamic situation.
On what basis do you conclude this heat results from a 1:6 speed increase and excess oil? On what basis have you quantified this heat dissipation? It would be interesting to see as we can then invalidate the accepted engineering design basis published in every mechanical design handbook I have ever encountered.
You have some objective basis for quantifying 10% vs 5%? Other that what it seems like to you?
Actually its closer to 7:1 when you think about it, [3600\540]. It seems you would ignore the fact that there is a point where "this is much hotter than that" becomes an objective determination. The reasons are things I know that contribute to the observed effect. Also, helical gears are used to ease the mechanical issues with the realitively tiny driven gear [which appears to be ground onto the end of the alternator shaft]. This geartype suffers greater losses than straight gears.
The facts remain. 13% loss to PTO on the Massey GC2400. 2% gearbox loss based on engineering design reference unless you can produce a reference to refute this.
Since it does not seem so I do not accept it as gospel. There are undoubtedly references that would deal with this more fully than a handbook. It would be good to be able to find a reference that discussed all the conditions of the real life power transfer in dynamic system application; ratio effects, motion effects, gear loss, bearing loss, viscous drag, windage, seal drag, etc. You can be sure that 98% efficiencies are not found in dynamic systems that have not been subject to scrupulous optimization for the specific condition of use. 90-95% is prevalent.
larry
/ PTO generator feedback #133
Interesting. We have some 100+ HP motors here where I work but I have not ran into that as we try not to dead-head those pumps!! If a flow-meter fails we used the amps to crudely judge flow. Good info.
/ PTO generator feedback #134
That must be one heck of a house.
Chris
It's a decent house, Built during the last "Great Depression" it does have 2 course thick brick walls on the first floor plus plaster on rock-lath for a total of ~12 inches. But it's not like it's such a perfect climate. I've got steam heat, new boiler but the old CI radiators.
So it's either to hot or a little cool. My boiler only goes on 2-3 times a day but stays on for an hour at a time :eek: We love the house, and I like steam, but I know some wouldn't like this type of system.
I'm sure your house is much more energy efficient and comfortable than mine.
/ PTO generator feedback #135
The difference reflects a HST power transfer system vs a spur gear transfer
There is a reason why there is nothing in Mark's regarding relevance of ratio. Because it is not relevant.
Do you think the handbooks do the tests themselves?.
No. They summarize collective (and accepted) engineering knowledge, experience and good practice that has been accrued on the subject to date. This summary is made available so the design engineer has a quick, easy to use reference that can be used to create reliable, effective, cost sensitive designs without having to perform detailed research for every subject he is interested in. That is the purpose of a engineering design handbook, by definition.
Bingo! We agree.
Provide a reference for this statement.
/ PTO generator feedback #136
objective hand heat test perhaps? :)
soundguy
/ PTO generator feedback #137
I thought those batteries were designed for so many charges, why would you have to replace them often? I wouldn't think a 1KW inverter would run a refrigerator, but could it run a TV or computer and a few lights. I would expect it to take a few hours to charge batteries, but that could be done during the time the genny would be running the heavier loads during the day, leaving the inverter for the evening hours when, if planed right the only electrical needs would be a few lights and TV/computer.
I guess I'm more thinking apocalyptic power outage, like a an environmental disaster where the power could be out for a month or more. and you really needed to ration electrical consumption.
I do realize 99.999% of power failures are between a few hours and a few days.
JB.
JB, I would not want to replace the batteries often and normally golf cart batteries last several years. It was a charger problem that may have damaged the batteries.
Yes the 1kw inverter can certainly run a few lights (switch to florescents recommended), TV, computer and small refrigerator.
I too think about long outages. During Isabel we were lucky and only lost power for one week, two weeks was normal and three was not usual. We had most of the people in VA loose power at least some. A lot of people here seem to be concerned with being comfortable. My main concern is water, refrigeration, lights and communications. The last two really don't take a lot of power. I have a large water tank so I can just run the generator for a short time and then go several hours if needed. I get heat from my fireplace and cook on the gas grill or microwave. I don't really need AC and getting a little cold is OK. Think of it as a camping trip. It is not as comfortable as normal, but much better than how people lived 100 years ago. The limitation is fuel. It's not the cost it's availability. During Isabel only one station had electricity and he ran out of gas in three days. I would fill all gas cans every day, even though I still had a lot.
I also try to stock lots of oil, oil filters, and a spare set of spark plugs. None of these will probably be available during an outage.
I would like to share generator use with my neighbor. We both have generators, but we could save a lot of gas if we just ran one. We live three hundred feet apart and a cord that long and 10 gauge (enough for 20 amps, 220 volts) would cost $600. We just could not justify this. The cord would not be able to run the well.
/ PTO generator feedback #138
I'm with dex on this one, what kind of water heater pulls 9500 watts? My 52 gallon has 2 4500 watt elements, but only cycles one at the time.
I could be wrong if they cycle and only one is on at a time. Guess I assumed two elements x 4500 watts each =9000watts. 4500 on each 110 leg. I never heard about them cycling back and forth. I won't dispute that they do (but it doesn't seem to make sense that they would). Are they cycling like a pulse, is one on for two minutes then the other one comes on? Guess I look at my oven (50 amp circuit), my water heater was a 30 amp circuit, and my generator circuit is a 30amp circuit so I figured I could do my water heater IF I did nothing else. Takes a lot of juice to heat water, (1 cal to heat 1 cc by 1deg. You can convert to watts but my physics class was a long time ago). I no longer have an electric heater so it's a moot point. I do have a 220volt well pump, a refrigerator, freezer, barn, and some more smaller stuff so I thought with electric water, well pump etc kicking on I'd easily exceed my 8000w surge, capacity. I now run everything in the house without a problem though I don't use my electric oven/stove, central air, or electric dryer. If anyone can explain why both elements in a hot water heater don't draw at the same time I'm listening. I thought it was a pretty simple on/off thermostat setup. When temp drops, elements come on until temp comes back to limit level.
/ PTO generator feedback #139
The difference reflects a HST power transfer system vs a spur gear transfer.
What do you think is the cause of such a difference? Hst does not drive the pto hydraulically. Could it be that the full picture is not being presented and that they cannot be accurately compared w/o knowing more about the tests??
Wrong. An omission of "fact" is not a statement of fact. I applaud Marks for not being wrong, but reduce it to one hand for not being complete.
No. They summarize each other for the most part. Critical evaluation is too often left to the user, who is sometimes not equipped.
Bingo! We agree.
I disagree that we agree. The premise for agreement is out of context.
Im tempted to have you find it yourself, but Im pretty sure you wouldnt look. ... See here: Other references to 90-95% for gear equipped systems are easy to find. Higher than that deserve a critical look.
http://web.mit.edu/2.75/resources/FUNdaMENTALs%20Book%20pdf/FUNdaMENTALs%20Topic%206.PDF
larry
/ PTO generator feedback #140
The most recent that I ran into was over 60 years old and in good repair. It is a 4160V 350HP with shaft out of both ends coupled to splt case horizontal pumps in a 2 stage configuration. I have used the current method to judge flow and it works good and it threw me for aloop when I ran into the motor/pump that reacted inverse to what I am accustomed. I wen serching after retesting and found the answer.
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
