PTO Driven Air Compressor
/ PTO Driven Air Compressor #1
anglerat
Winona Lake, IN
JD 2210
Anybody have any exprience w/ a pto driven air compressor?
I saw one in Northern Tool and it seems it could be pretty useful.
Do they have enough capacity to do much w/o a significant reservoir?
Thanks guys.
Aaron
/ PTO Driven Air Compressor #2
i was wondering about this compressor also, anyone have one?
alex
/ PTO Driven Air Compressor #3
I bought one from Northern Tool. I have used it a couple of times. I have a air powered limb clipper. It worked fine with it. It is very simple to use.
/ PTO Driven Air Compressor #4
how do they deal with the pressure buildup since the pto would be running continuosly, whereas an electric compressor turns off when the pressure is reached, do they just use a relief valve with a high flow rate or do they have and unloading valve like they use on gas powered compressors? i have been thinking of rigging up a compressor head to mount by the 3pt and run off the pto but i gota figure out how they regulate it
/ PTO Driven Air Compressor #5
Not sure how they do it but the compressors I have seen that run constantly have a modulating valve that either unloads extra air or kind of free wheels when the pressure in the receiver reaches set point.
/ PTO Driven Air Compressor #6
I think some of the Zetor tractors come with an air compressor on them !
/ PTO Driven Air Compressor #7
This is a neat idea, but the flow rate is on the wimpy side.
You won't be running a 3/4" impact off that compressor effectively.
I wonder how much more costly a pto compressor designed to run off a tranny pto for a truck would be, and if it would work on a tractor.
Fred
/ PTO Driven Air Compressor #8
An old thread, but found interesting.
Does that Pto powered air compressor you mention look like this? (see attachment)
If so, it has a two-sided very simple piston operating linearly. That piston is driven at its middle section by the pto. Air is sucked into the cylinder from one side and pumped out from the other side of piston head. Since this pto compressor doesn't have an extra air chamber to keep the air flow continuous you can't use it for painting purpose. Can be used only to inflate the tires. But, a small extra air chamber can be made easily when making the model casting. Then, it can also be used for painting as the air flow will be more continuous (no flow interruption).
/ PTO Driven Air Compressor #9
Wrecking yards drive their air impact wrenches using an air conditioning compresser, belt driven off the motor. Seems to work well and they have an unlimited supply of them...
7in. Auger Bit (A65640)
7in. Auger Bit...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2022 EZ-GO ELITE...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
