Snow PT 425 with 48" Snowblower
/ PT 425 with 48" Snowblower #1
Clumber
Northern Virginia
Kubota B2601 HST Nov 2019
Hey Folks, new member here! In the near future I plan to buy either a Power Trac 425 or a Ventrac 4100 tractor. My question today is related to snow blowing on the Power Trac 425 with the 48 in snow blower attachment. Is it powerful enough to handle my situation described below?
We live on a 42 acre rural tract in Northern Virginia near Winchester. The areas that needs to be plowed is a mile long private gravel road (crusher run blue stone) and about half an acre of fenced grass and dirt where our show dogs need to go out several times a day. Several times during last 8 years there have been blizzards dumping 36-40 inches of snow in a 24 hour period. I have neighbors with large farm tractors that help us by plowing the areas using loader buckets and three point plows. The problem is that the grassy area get rutted by the weight of the tractors and the gravel has disappeared from the road due to all the scraping trying to break up the ice that eventually forms after plowing. Before putting more gravel down I need a better solution. Here is the plan:
1. Use a PT425 with 48" snowblower set at 1-2" above the gravel to remove most of the snow.
2. Before the remaining 1-2"s freezes up, use a leaf/debris blower attachment to blow off the remaining snow. Of course Power Trac does not have a debris blower attachment so I would have to rig a walk behind blower on pallet forks, etc... Ventrac has 2 debris blowers to choose from. Anyway, my thinking is that this plan will keep the road from freezing up without also losing the gravel.
3. Use the spreader attachment to lay sand down when there is ice.
4. A debris blower will also work on the remaining 2" on the grassy areas. A power brush might also work on the grassy area as well.
The more I think about it, it's doubtful that the PT425 will have enough power to handle 40" of snow. I'm not sure I want to shell out another $6,000 for the PT 1430. The Ventrac setup will also probably cost at least $7000 more with the debris blower. I am thinking about getting the PT425 and just trying to go easy when the heavy stuff comes down. Too bad Power Trac does not make a debris blower.
/ PT 425 with 48" Snowblower #2
The ventrac with the cab is just too cool. Yes it is expensive, but hey.....
I agree! Really like the Ventrac as a slope mower, for snowblowing and also has a debris blower attachment available as well. However, the Power trac has more versatility with the other many attachments. I am tempted to get both but finding it hard to justify the cost.
I have seeen lots of videos and discussions on the Power Tracs with amny attachments. However, I have not seen one video of anyone actually using the PT 425 with the 48" snowblower.
/ PT 425 with 48" Snowblower #4
One thing the Power Trac can do that the Ventrac cannot do is lift the snow blower up 60" into the air. If the blower is 18" tall, you could, in theory, clear six and a half feet of snow.
I do not have the PT snow blower, so I have no idea how well it works.
Also, welcome to TBN! :)
/ PT 425 with 48" Snowblower #5
The PT blows away the Ventrac with regards to being a loader. Because the engine is up front on the VT, the weight distribution is not nearly as good. Still, I would rather snow blow in the VT with the cab over the PT any day.
You don't need to lift the snowblower that high to remove 6 feet of snow. You can burrow under and then let the stuff on top fall. As long as the chute can throw it over the top. Been there, and done that.....
To be perfectly honest, I think the best snowblowers are the walk behinds. I have a big Ariens, and it works great. It is more maneuverable than a tractor attached snowblower.
/ PT 425 with 48" Snowblower #7
The blower with the cab looks really good. The plow looks kinda weeny if you can't lift it up very high, though.
/ PT 425 with 48" Snowblower #8
I like the V plow. Somebody should build one for their PT.
/ PT 425 with 48" Snowblower #10
I have the PT425 with the snowblower attachment for the past 2 winters and it works very well, but does not have the control of the chute distance as well as the Ventrac. It does have excellent control of direction of the snow. I will tell you that there is no way you will blow the 1" to 2" deep snow left after plowing or snowblowing with any blower, especially if it has been under 2 to 3 feet of snow. You might might get it off with a powerbrush, but I'm not sure it is worth it. Good luck with your decision.
Thanks DCWhitley, I did not think of the compaction issue. I did think that using a blower would not work well on heavy wet snow, only on light dry stuff. I guess all I can do is try various things. What is your experience with PT425 Snowblower under say 36" of snow. Do you have to go extreamely slow vs a mowing speed? Have you used yours on a gravel driveway? I am also concerned that the drive chain is exposed on the business end of the snowblower. Any problems with that?
/ PT 425 with 48" Snowblower #12
Great job on that blower! Have you used it on a grass, or a gravel driveway? Does it blow away the gravel as well? I was thinking of bying a used gas powered walk behind leaf blower and attaching it to palet forks...
Also, the BLower Buggy Carrier is someting worth considering:
JRCO Blower Buggy Carrier
/ PT 425 with 48" Snowblower #14
We haven't had 36" since I have had the snowblower, but I will say that the first pass has to be very slow in deep (18") snow or it fills the chute and you end up "plowing" the snow, not throwing it. Once the first pass is completed, you decide between speed and how much you want to take at each pass. I tend to prefer faster speed(mowing) and a smaller cut.
My driveway is gravel (not stone) and is frozen most of the time,(early Nov to April most years) so digging it up is not a problem. Last year was unusual and we had some snow after the spring thaw and the guys who plow had a big problem digging in. I just tilted my snowblower back so the front edge was 1" off the ground and rolled on the wheels; I didn't dig in at all.
The exposed chain has not been a problem for me, but I will say they could have designed a better way to keep it tight.
Hope that helps
Hope that helps
Thanks for that very useful info. Please tell us more on the chain issue when you can. Does the auger have serrated edges?
I am pretty sure that the PT 425 with 48" snowblower will work for me.
/ PT 425 with 48" Snowblower #17
I used it on my gravel driveway just have to raise it up a little so it doesn't pick up to many stones. That thing has some serious air volume. I paved my driveway since then but I have to use it to blow all the leaves and wild cherry seeds off of it. I also used it to clear it before I sealed it as well. I like that I can raise it up high and tilt (draft) it down and it just keeps blowing. It clears my 2 acre property of all the leaves in the fall to. The thing of it is that it works for me and does exactly what I want it to do. I also debated about attaching one of those motorized units to my forks but they don't have as much air volume as the steiner blower did. I also didn't want to take care of another gas engine and I already had the blower.
/ PT 425 with 48" Snowblower #18
Well Clumber, now that you said this, if you get the Power Trac you will have to post pics and vids of the blower in action;)
Like you I am anxious to see video of the PT snowblower:drool:
I will be happy to do so. However, once I buy the PT and and the snowblower it will probably be 5 years before we get any heavy snow fall. :)
/ PT 425 with 48" Snowblower #20
Thats good, scare that nasty snow away. Think of it as insurance against the snow :)
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
CAT 930M (A58214)
CAT 930M (A58214)
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2015 Ford F-150...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
