PT-425 mini-hoe dimensions
/ PT-425 mini-hoe dimensions #1
hikerjohnson
Southern Maine
MasterTill
Hi folks; I;d like to take a go at making my own mini-hoe for my PT-425. Is anyone out there will to share the important dimensions? A nice square-on photo with something of know size would be prety OK to scale off, too.
Thanks in advance!
/ PT-425 mini-hoe dimensions #2
Thanks in advance!
Iff you don't get one before I get home, I will take a picture with a tape measure clearly visible.
/ PT-425 mini-hoe dimensions #3
Thanks in advance!
How old is you unit? I have a 2001 and would be glad to get you the dimensions for anything you need if it is a older rig.
Thanks all; mine is circa 2017, but I'm not sure it matters much for the mini-hoe attachment. I'm a welder-fabricator, so the mounting plate and bucket are no trouble, I just want to know what the linkage lengths and pin distances are.
/ PT-425 mini-hoe dimensions #5
20240601_102012.jpghope this helps
/ PT-425 mini-hoe dimensions #7
2010 Ford F-250 XLT (A64127)
2010 Ford F-250...
16ft. Field Cultivator (A65640)
16ft. Field...
(3) Tires (A65640)
(3) Tires (A65640)
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
John Deere Tractor Step (A65640)
John Deere Tractor...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
