PSI
Mark Page
Platinum Member
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
How much pressure does a diesel engine use to force fuel through the injectors? No doubt not all are the same.
You're right, they are not all the same. Nozzle opening pressures can vary quite a bit for any number of reasons. I have seen some as low as 1800 psi and others at 3000 plus. Most tractors will fall in the 2200 to 2800 psi range
Indirect injection is around 1500 PSI and common rail injection around 15000 PSI and yes it varies with different systems. at least thats what i have read.
Some diesel truck engines are over 20,000 psi., my Duramax is 23,000 and newer ones are higher.
All depends on your pumps and injectors. I have a modified LBZ D-Max and I have a custom set of injectors and when in order to have keep fuel going at full HP I'm running close to 40,000psi. In the last few months since I've updated my fuel system I've doubled my HP and little over tripled my torque
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
2023 JOHN DEERE 35P EXCAVATOR (A65056)
2023 JOHN DEERE...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
BX23 TLB 10k OBO
BX23 TLB 10k OBO
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2014 (INOPERABLE) FREIGHTLINER CASCADIA (A67714)
2014 (INOPERABLE)...
