PSI
Mark Page
Platinum Member
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
How much pressure does a diesel engine use to force fuel through the injectors? No doubt not all are the same.
You're right, they are not all the same. Nozzle opening pressures can vary quite a bit for any number of reasons. I have seen some as low as 1800 psi and others at 3000 plus. Most tractors will fall in the 2200 to 2800 psi range
Indirect injection is around 1500 PSI and common rail injection around 15000 PSI and yes it varies with different systems. at least thats what i have read.
Some diesel truck engines are over 20,000 psi., my Duramax is 23,000 and newer ones are higher.
All depends on your pumps and injectors. I have a modified LBZ D-Max and I have a custom set of injectors and when in order to have keep fuel going at full HP I'm running close to 40,000psi. In the last few months since I've updated my fuel system I've doubled my HP and little over tripled my torque
Unused Hustler DG LM200 SS 79in Hydraulic Dual Cylinder Grapple Loader Tractor Attachment (A66734)
Unused Hustler DG...
2007 FORD F-450 SUPER DUTY BUCKET TRUCK (A67714)
2007 FORD F-450...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
GAYLEAN  130BBL VACUUM TRAILER (A67714)
GAYLEAN 130BBL...
2023 Unused Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
2023 Unused Del...
