Proper way to connect chain
   / Proper way to connect chain #11
I use 3/8" grab hooks on my stuff, even though most of my chains are 5/16". No problem there. I go for larger on my slide hooks.
   / Proper way to connect chain #12
I have 3/8 grab hooks too. They hold 5/16 and 1/4 chain no problem. I went with the larger hooks so on lighter but bulky loads I can hook/tie a decent size rope into those hooks and keep stuff in the loader.
   / Proper way to connect chain #13
Same setup as Short Game, grab hooks on ends amd slip hook in center. It's a very versatile setup but I imagine any hook is better than without!
I have four 3/8 chains but usually use my one 5/16. It is much easier to handle.
I like the drawbar clevis setup by Babygrand. Excellent idea...I will copy that one.
   / Proper way to connect chain #14
I also have the same setup as Short Game and it works well.
A few times of trying to wrap the chain around the bucket to
get the right length will convince anyone of the need for bucket
hooks. I love the chain saddles, I have three, one old one and
two newer ones. They are really nice when trying to adjust a
chain with cold muddy hands. I carry one on the tractor the same
way Baby Grand does.
   / Proper way to connect chain #15
Same here, though most of my pulling is from a wrap around the trailer ball on my box blade to a grab hook at the top corners of that. I may add more hooks there too.
P.S., I love my chain box too. You can put a lot of chain in a small box.
Will any size chain fit on these?
Also, where do you keep your leftover chain length so it doesn't drag?
   / Proper way to connect chain #18
I use 3/8 inch grade 43 chain but a 3/8 grab hook will work with 1/4 inch chain no problem. I just let the excess chain drag on the ground, it won't hurt the chain.
I keep two 20' lengths of chain in a 40mm ammo box on the top of my ballast box. I have found it is always handy to have chain at the ready when working in the woods. I also have some of Ken's bolt on grab hooks on my bucket and my Artillian pallet forks even have some grab slots which are really handy too.
I have another 40' of chain I can also bring down into the woods if I want to pull down a hung tree from a safe distance.
   / Proper way to connect chain #19
I went to my local Ace Hardware to get chain and hooks because I wasn't sure what I was doing. Based upon their advice, for each chain I bought two different types of hooks.
The hardware is shown nicely at this web site:
Chain Hardware Wire Rope & Hardware Distributors Elite Sales
As mentioned above, I put a "screw pin anchor shackle" on my draw bar - it makes a nice connection point for pulling. I don't have hooks on my FEL, but hooking a wide-opening chain hook onto the lip of my FEL seems to do OK for my needs. The first time you lift with the FEL and find your underweighted rear rear rend come up (pivoting on the front axle) you'll be kind of surprised. THAT is why you want to have adequate rear weight, AND do all lifting slowly, so you don't get into trouble. Also, make sure you don't try to do running jerks with the chain - or else you're likely to damage something.
I put a "clevis slip hook" on one end of the chain. This hook has a larger opening that will hook around the clevis pin, the lip of my FEL, and other objects.
On the other end of the chain I put a "clevis grab hook". This hook has a smaller slot-shaped that is designed to slip securely over a link of the chain - creating a chain loop. Its important that the grab hook size is matched to the size of the chain, so you get a nice connection. I've found it works well to have two shorter chains (so I can hook both chains on an odd-shaped object - such as a rear blade and lift it with a FEL), and a single longer chain (for pulling SMALL stumps and such ... larger stumps need to be dug out first ... at least for me).
Having a different type of hook on each end gives nice flexibility.
   / Proper way to connect chain #20
If the torque tube of your loader is open on each end you can slide a chain thru it and chain the loader down that way.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2021 CHEVROLET LCF 4500 16FT BOX TRUCK (A59575)
2021 CHEVROLET LCF...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
