I found some of the CHP data. It is hard to find and not at one link.
I copied the info on chain binding below. Basically it states that the chain and binders you use must have stamped ratings on the device. Grade 43 and 70 chain is stamped on each link as such. Same for hooks. It sounds like only chain made by a manufacturer that provices the CHP with samples of their chain and markings
are authorized for use in California. Most chain sellers will
indicate if they are CHP approved
. Here is the relevant info from the CHP site
I did not find the portions on how to attach to trailer or
item to be bound)
(g) Binder attachments shall have a design strength or load rating not less than that required of the binders to which they are attached.
(h) Chain hooks (Fig. 2) shall be of the clevis-type except as follows:
(1) Closed-eye chain hooks of the appropriate size and grade may be used when the hook grade is identified by the manufacturer's permanent and distinctive mark.
(2) Chain binder assemblies with chain hooks joined by flash- or butt-welded connecting links shall bear the manufacturer's permanent and distinctive link grade mark.
(3) Manufacturers shall provide the department with a list of the marks of identification used on closed-eye chain hooks and chain assemblies.
