Proper Cold Weather Starting
/ Proper Cold Weather Starting #21
Some Yanmars came with bottle that has to be filled and some came with bottle filled by injector leak by. Some came with neither .
/ Proper Cold Weather Starting #23
:laughing: Yeah like mine. None!!!
/ Proper Cold Weather Starting #24
/ Proper Cold Weather Starting #25
Why full throttle and then pull it back 1/2 way? And do not run a Cold Engine at full throttle? That's what your be doing, Starting and Running it at "Full Throttle" Kind of hard to Turn the key and hold the Throttle Lever. So IMHO. that's must be a Translation error.
/ Proper Cold Weather Starting #26
Thank you sir! I assume it then says turn to ts for a period of time? Does it say antyhing about starting the engine and while it's warming up to go back to ts?
No idea why anybody would use a thermal start to clatter a cold engine to life ? Plug in the block heater instead .
I use the block heater when possible, but there isn't always mains power around.
Over the weekend I got the decompression mechanism fixed. My dash lever now turns the decompression gizmo on top of the engine. The thermostat device isn't ready for primetime yet. The wire that leads from the ignition over to the engine is missing quite a bit of insulation so I need to pull a new piece as a replacement.
Since the weather is drier this week I can just keep the tractor parked near that house and use the block heater.
Thanks for all the input and instructions. I think with a small hose clamp and a new piece of wire I'll be able to get the cold weather start sorted out. Many thanks.
/ Proper Cold Weather Starting #29
Added 3 more pages out of operation manual in post #24.
/ Proper Cold Weather Starting #32
That's an OEM manual. Yanmar no doubt has bi-lingual tech writers. You, (I,) can easily throttle back before it reaches full rpm's.
/ Proper Cold Weather Starting #33
Say the engine is cold and throttle sticks wide open from being Cold,Frozen,Dirty. What are you going to do. Turn the key off :D
/ Proper Cold Weather Starting #34
Ask the Yanmar engineer that wrote the manual.:confused3:
/ Proper Cold Weather Starting #35
BS. It was wrote 40 yrs. ago and not going to happen. It says Do Not RUN COLD WIDE OPEN. Not do not Start @ Half Throttle. If it starts And your moving it that Quick what's the difference? There's Not One!!!
/ Proper Cold Weather Starting #36
All I know is I ALWAYS start with throttle wide open and NEVER, EVER run the engine wide open. Don't even know what top rpm is.
/ Proper Cold Weather Starting #37
Starting It full throttle and not running it that way. So your saying You start it with your Left Hand Turning the Key and your Right hand on the Throttle. How do you use the Decompression? With that little finger between your legs??? :rolleyes:
/ Proper Cold Weather Starting #38
In my experience on the YM240, 1/3 throttle is all it needs on a cold-weather start. I used full throttle in the beginning as the Operator Manual recommends. The only difference that makes is a huge cloud of black smoke in the moment before I can yank the throttle back to 20%. Starting at lesser throttle makes minimal smoke.
But even using a 100% throttle start, there's time to pull the throttle back before it revs to maximum so I don't think this stresses it the way an automobile engine would go to peak rpm instantly.
Also - the manual says warm up at 1500 rpm. That sounds fast, like its hard on a cold engine. Just above cold-engine diesel clank, maybe 1200 rpm, sounds like less stress.
Last week I started the YM240 with the barn still below 40 degrees after it hadn't been started for weeks. First time in several years it didn't catch instantly. I think the battery was down to about 12.3 volts and I didn't run the Thermostart for the full 15 seconds that I should have. Second attempt after running the Thermostart until I heard the vapor burst into flame, started normally. (I always begin a first start of the day by spinning it with compression released to get oil pressure up, and on every start release compression while the starter turns the engine the first couple of revolutions).
I would have put the 2/10/50 charger on it, let it charge for a couple of minutes, and cranked with the charger set on 50 amp assist to make it spin faster, if that had been needed. Before I replaced the starter and injectors five years ago I sometimes had to do that in cold weather.
The more modern 3-cylinder YM186D starts easily like a car. I use the same procedures but they aren't really needed.
/ Proper Cold Weather Starting #39
You do it your way, carey, I'll do it mine.
/ Proper Cold Weather Starting #40
I decompress, crank till oil gauge starts moving then release decomp and step on the throttle to get fuel to fire up and then adjust hand throttle to suit. I usually sit it about 1000-1100 rpm as it clanks way less at those revs.
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2001 GMC C6500 Dump Truck, VIN # 1GDJ7H1EX1J901196 (A65563)
2001 GMC C6500...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
1987 FORD F-8000 ROLLBACK TRUCK (A64277)
1987 FORD F-8000...
2009 Dodge Charger (A64194)
2009 Dodge Charger...
