Propane Tank Back Blade Build
   / Propane Tank Back Blade Build #1
mazzbob
troy built
A friend gave me an Old 100 lbs. Propane Tank. I decided to use it, and build a Back Blade. I used a drill press, stick welder and a 4.5 inch hand grinder to complete this project. I used the Brinly Moldboard Beam, whereby there are some adjustments to the cutting angle. I also had to reinforce the Sleeve Hitch for strength. There are 30°, 45°, 90° Blade angle adjustments on Horizontal and Vertical plains. So far I have done some trial Soil Leveling which has worked well.
   / Propane Tank Back Blade Build #3
mazzbob,
Excellent repurpose/ upcycle of scrap metal. Sure beats turning a propane tank into a potential hand grenade like another thread got involved in.
   / Propane Tank Back Blade Build #6
Very nice!
Just made some Wing Nuts for it. Now I don't have to use a wrench. Thanks, for the kind comments.
   / Propane Tank Back Blade Build #8
Very nice job! That will surely help you do some work!
   / Propane Tank Back Blade Build #9
keep an eye on that rear linkage. Back blades tend to exert a great deal of side loading forces and might bend that all up, so ya may end up applying some 3/8" thick x 2" angle iron to those members. nice execution.
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
