Propane Tank Back Blade Build
   / Propane Tank Back Blade Build #1
mazzbob
troy built
A friend gave me an Old 100 lbs. Propane Tank. I decided to use it, and build a Back Blade. I used a drill press, stick welder and a 4.5 inch hand grinder to complete this project. I used the Brinly Moldboard Beam, whereby there are some adjustments to the cutting angle. I also had to reinforce the Sleeve Hitch for strength. There are 30°, 45°, 90° Blade angle adjustments on Horizontal and Vertical plains. So far I have done some trial Soil Leveling which has worked well.
   / Propane Tank Back Blade Build #3
mazzbob,
Excellent repurpose/ upcycle of scrap metal. Sure beats turning a propane tank into a potential hand grenade like another thread got involved in.
   / Propane Tank Back Blade Build #6
Very nice!
Just made some Wing Nuts for it. Now I don't have to use a wrench. Thanks, for the kind comments.
   / Propane Tank Back Blade Build #8
Very nice job! That will surely help you do some work!
   / Propane Tank Back Blade Build #9
keep an eye on that rear linkage. Back blades tend to exert a great deal of side loading forces and might bend that all up, so ya may end up applying some 3/8" thick x 2" angle iron to those members. nice execution.
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
10x16.5 Tire Assembly (A52748)
10x16.5 Tire...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
