Propane Regulator freeze
/ Propane Regulator freeze #1
woody
Veteran Member
Central Alabama
Kubota B26, Kubota ZG222, Kubota L45, 1980 Ford 1700
Okay I installed a gas fire place last year and about half way through the tank of fuel my gas logs went out and would not lite back up. since the fire logs where new to us we did use them a lot so I thought we had used up the gas but after checking the gauge it showed half a tank but still no gas to the logs. I called the gas company to have the tank checked and filled and he said it was half full that the regulator must have froze up. that's not good since this is my back up heat for the house. is this possible and what can I do to prevent it from freezing again?
/ Propane Regulator freeze #2
Vendor claimed that would happen if I insisted on using 20# tank and regulator. They installed two 100# tanks and and auto-changeover regulator. Can't say I have really put it to the test but it hasn't froze.
/ Propane Regulator freeze #4
A 20LB cylinder has about 4 gallons of LP when full and will vaporize the liquid until empty. How many btu is the log set ? Was there a frost line on the tank while the log set is running ? I would suggest a larger tank filled by an LP company so that any inherent moisture issues with the LP are taken care of by the LP company.
/ Propane Regulator freeze #5
I have 2 regulators. One at the 500 lb tank and one at the house. The one at the house will freeze up during the winter if it gets moisture inside it. Hot water over the regulator will un thaw it. I have since started wrapping the regulator in the winter months with a packing blanket and have never had another issue. So the tank size has nothing to do with it. The LP company recommended the hot water trick and then I came up with the wrapping trick. But in actuality I should probably build a little roof over the regulator to keep out the moisture.
/ Propane Regulator freeze #6
I have 2 regulators. One at the 500 lb tank and one at the house. The one at the house will freeze up during the winter if it gets moisture inside it. Hot water over the regulator will unthaw it. I have since started wrapping the regulator in the winter months with a packing blaket and have never had another issue. So the tank size has nothing to do with it.
well that is incorrect. Tank that is too small and uses an integral two or single stage regulator is more prone to freeze ups than a 500 with a first stage / second stage. You may ask your propane supplier to add some methanol.
/ Propane Regulator freeze #7
I think it's more about where the regulator is located than anything. North side of the house and is only affected by freezing rain, snow seems to have no affect. But thanks
/ Propane Regulator freeze #8
An undersized regulator would do this. You need to know the BTU of the log lighter and size appropriately! I’m going to take a SWAG and say you are using an undersized el cheapo regulator.
/ Propane Regulator freeze #9
Doofy will be able to relate to this. The year we lived in Glennallen, AK our cook stove was propane. We had a 100# propane tank outside. When we would get up in the AM - alway flip the switch and turn the small heat lamp on. The heat lamp heated up the propane regulator. Things would flow - we cooked breakfast.
/ Propane Regulator freeze #10
This was a definite problem back when Alaska got cold, really cold. Now, not so much. We either used a light bulb near the regulator or would hold our finger over the vent and pour hot water over the regulator. The real pain was hauling that 100 pounder to town to be filled. I could not carry that now.
/ Propane Regulator freeze #11
Just be sure you leave the regulator vent open when you wrap it.
/ Propane Regulator freeze #12
I think you need a different gas supplier if they didn't answer these questions then help you prevent a reaccurance.
I
/ Propane Regulator freeze #13
I have had my regulator next to my house freeze up in -20* degree weather at night and what I do is poor tap water on it and tap it with a hammer and it would open back up, I have had to do this a couple times in cold winters and finally last year when we were having -30 temps it finally stopped working all together( condensation and rubber do not go hand in hand in cold weather), had to have the propane company come out and put a new one on, the one that went bad was at least 30 years old. Thank goodness for backup heat.
Okay first of all thanks for the replies. I'll try to answer some of the questions.
the tank is a 120 Gallon tank and is maintained by the local gas company.
the logs are 24K BTU on low and 32K BTU on high
the tank is on the Northwest side of the house
I can run a light out to it, but I am concerned about putting a possible ignition source that close and since it is my back up heat the power would be out when needed the most anyway.
/ Propane Regulator freeze #16
It will help if you wrap in some insulation during the colder days. I had to go to my MIL's house the other day when we had that cold spell. Her regulator was froze and wouldn't supply her furnace with enough gas
Where in AL are you ?
Talladega, but I have not used it this year was remembering it happening last year
/ Propane Regulator freeze #18
That sounds like it would make the problem worse, not better.
Assume the liquid in tank has cooled to ambient temperature. Then it expands in regulator, gets colder when it expands. Air is warmer than the regulator. Insulating the regulator only helps keep it away from the warmer air making the problem worse.
This is a problem for CNG and LP vehicles where heated regulators are common.
/ Propane Regulator freeze #19
Yep, the forklifts at work have regulators that take liquid propane, heat it with coolant and vaporize it to burn in the engine.
Aaron Z
/ Propane Regulator freeze #20
Most propane tanks have a flip over top. I insulate them and close the top. Never have any more issues unless the insulation gets removed.
Only reason my MIL had an issue the other day was, the propane company removed the insulation when he filled the tank last time and didn't replace it
2019 CATERPILLAR 289D SKID STEER (A65056)
2019 CATERPILLAR...
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
2025 Sickle Bar Mower Mini Excavator Attachment (A66734)
2025 Sickle Bar...
2018 BOBCAT E26 (A68134)
2018 BOBCAT E26...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
