Transferring propane from old tank to new one
   / Transferring propane from old tank to new one #11
A gravity transfer or differential pressure transfer is a "slow boat to China". Worked for a company where we had to fill the tanks on the fork lifts this way. The "big cheese" saw me sitting outside for hour and a half - doing nothing but waiting. We had a brand new transfer pump the following week.
   / Transferring propane from old tank to new one #12
My experience with a large propane company is not great and they seem to know every trick in the book.
I would suggest hooking up your old tank to the house temporarily and using the propane until it is empty and then switching. I'm a little surprised that your new company didn't offer to do that.
I would factor in what the time/mental hassle might be to get paid for "your" propane remaining in your old tank. After my experiences, if you can't do a temporary hook up, I would be inclined to write it off as the cost of having done business with the old company.
We are in the process of switching from propane because our experience was so unpleasant over something that could have been easily handled by the propane company and was entirely their fault. (Their tank leaked my propane, and they dragged their feet about both replacing the tank, and for (partially) reimbursing us for our lost propane. It took months, and in the end had interventions by attorney generals in more than one state. I think that it was the ugliest (on their part) interaction that I can recall with a business.)
So, yes, I don't have an especially high opinion of at least one propane company.
All the best,
Peter
   / Transferring propane from old tank to new one #13
Here is a nice explanation of the "ideal" way to perform propane transfers.
When propane powered tractors or trucks were common. The most common way was a single transfer line connected to a liquid draw line and valve on the main tank or nurse tank. When the liquid line was connected to the empty tank and the liquid valve opened there might be a small amount of propane transferred till pressure was equalized, but you would never get a filled tank that way.
However as soon as the vent to atmosphere valve on the tank being filled was opened to allow vapors to escape the fuel would begin transferring. We would continue to transfer propane as long as vapor was leaving the tank being filled, once the vapor vent began to spew liquid it was closed, then the nurse tank valve was closed and the valve at the end of the fill hose, then the fill fitting was cracked loose to bleed of the pressure.
These are the pressures your propane tank see's and that the vapor regulators control down to a few inches of pressure or about a 1/3 of a psi.
Vapor pressure of liquid propane at various temperatures
Temperature of Liquid (F) Approximate Pressure of Gas (psi)
-401.3
-305.5
-2010.7
-1016.7
023.5
1031.3
2040.8
3051.6
4063.3
5077.1
6092.5
70109.3
80128.1
90149.3
100172.3
110197.3
All the best,
Peter
Hooking up my old tank is an excellent idea. It's probably going to sit out here for a long time. Any idea what kind of threaded ends will fit these 325 gallon home tanks?
Thanks,
   / Transferring propane from old tank to new one #16
Thanks,
Should be the standard POL,
Okay y'all.
This:
And this:
Netted me this:
   / Transferring propane from old tank to new one #18
That will be about the easiest way, only issue will be deciding when to switch back. Or, when the other company comes for their tank.
   / Transferring propane from old tank to new one #19
For future readers...
Those loops on each end of the propane tank are tie-down loops, used for hauling on a trailer.
If used for lifting, they could be ripped off if there was enough liquid in the tank. If the tank is near empty, it's ok to lift there.
The safest way to move a tank is wrapping a chain under the tank at both ends, so that the feet prevent the chain from sliding toward the middle.
Well I honestly doubt they will be coming by to get the tank anytime soon knowing this companies reputation, and people claiming to have to keep pressing them to get their tanks out their yard. If they do however come get it before I run the gas out then they'll need to unhook it, and I'll hook right back up to my new tank.
Do I think these are tie-downs I lifted from? IDK, maybe, but wrapping 2 straps over the top of both sides of the tank, and pulling it against the floor of the truck would likely be the better tie-down option if this part of the tank is that weak. All the gas companies around here lift off these points, and they always deliver with only around 30% of the tank full I assume to not have to deal with the weight of a full 325 gallon tank while lifting it. This tank was only filled with low 20% gas range remaining. Heavy? Yes, to a certain extent, but I'm pretty sure it didn't overstress the tank or put micro-tears in the welds where the bands are welded to the tank. If gas companies would allow for the exchange of peoples gas from an old tank to a new one when converting over then this would be a none issue. Gas is expensive, and I've already paid for it. Like anything else that involves being a man, be smart. Start early. Learn to change your own oil, build an engine, enroll in BJJ, basically just learn how to be a man, then you can make wise decisions when it comes to doing man things like moving gas tanks, or pulling out before you bust.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51242)
KNOW BEFORE YOU...
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
