Prop Nut needed
/ Prop Nut needed #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
TBN member needed to do a small nachinest job. Need a special nut created to fit a molel engine propeller.
Only 2 critical dimensions Outside dia. of round part & internal threads, 1/8 by 24 (national fine)
1/2 in depth. Other din. not critical about 3/4 inches long. 5/8" on the front part. Can be hex shape at rear of nut and / or a 1/6 hole near the center.
If you are interested let me know how many $$$ & how long it will take.
Thank you,
Jim
/ Prop Nut needed #2
Can't help with the part, but that looks like the variable pitch prop I had on a U control model beck in the early 60's. Made by Johnson as I recall.
/ Prop Nut needed #3
Thank you,
Jim
There is no 1/8 x 24 NF size, want to verify that? Also, sometimes you can get internally threaded hex stock (connectors) than can be chucked up and shaped externally as needed.
/ Prop Nut needed
Shaft is 10 / 32
/ Prop Nut needed #5
Shaft is 10 / 32
Based on 10/32 that is 5/16 - 24. Nothing special about that size. You need it with a blind hole and bullet nose? Steel or brass may be too heavy. You may want aluminum.
/ Prop Nut needed #6
McMaster-Carr? They seem to have everything.
Jim
/ Prop Nut needed #7
Just curious.....what is that prop off of?
/ Prop Nut needed
A little better measurement says 1/4 28. shoul some 1 make 1 I will send a crank for the to measure.
It fits a .45 + or - size model engine, the center needs to be snug so it does not vibrate. at 10,000 rpm
/ Prop Nut needed #10
yeah, that rpm is going to scare off a bunch of home shops, lol!!! Balance is tough to get right!
David from jax
Skid Steer Smooth Drum Roller (A65640)
Skid Steer Smooth...
John Deere D110 Riding Mower (A62679)
John Deere D110...
2014 FREIGHTLINER CASCADIA (A65643)
2014 FREIGHTLINER...
2022 EZ-GO ELITE...
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
7x16 Enclosed Spray Foam Trailer (A65563)
7x16 Enclosed...
