Prop Nut needed
/ Prop Nut needed #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
TBN member needed to do a small nachinest job. Need a special nut created to fit a molel engine propeller.
Only 2 critical dimensions Outside dia. of round part & internal threads, 1/8 by 24 (national fine)
1/2 in depth. Other din. not critical about 3/4 inches long. 5/8" on the front part. Can be hex shape at rear of nut and / or a 1/6 hole near the center.
If you are interested let me know how many $$$ & how long it will take.
Thank you,
Jim
/ Prop Nut needed #2
Can't help with the part, but that looks like the variable pitch prop I had on a U control model beck in the early 60's. Made by Johnson as I recall.
/ Prop Nut needed #3
Thank you,
Jim
There is no 1/8 x 24 NF size, want to verify that? Also, sometimes you can get internally threaded hex stock (connectors) than can be chucked up and shaped externally as needed.
/ Prop Nut needed
Shaft is 10 / 32
/ Prop Nut needed #5
Shaft is 10 / 32
Based on 10/32 that is 5/16 - 24. Nothing special about that size. You need it with a blind hole and bullet nose? Steel or brass may be too heavy. You may want aluminum.
/ Prop Nut needed #6
McMaster-Carr? They seem to have everything.
Jim
/ Prop Nut needed #7
Just curious.....what is that prop off of?
/ Prop Nut needed
A little better measurement says 1/4 28. shoul some 1 make 1 I will send a crank for the to measure.
It fits a .45 + or - size model engine, the center needs to be snug so it does not vibrate. at 10,000 rpm
/ Prop Nut needed #10
yeah, that rpm is going to scare off a bunch of home shops, lol!!! Balance is tough to get right!
David from jax
ATS Mini Excavator (A66285)
ATS Mini Excavator...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A65054)
2016 INTERNATIONAL...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
