Problem / 6 way blade
/ Problem / 6 way blade #1
duke7595
S/W MO.
820 ,1520,1020 (D) 1020 (G) 1050,4020 2240
I have a problem with the angle part of the 6 way blade all other functions work ok.
The machine had been setting for several months and upon starting it, I became aware that the angle does not function either way, it makes 00b0b_TcNZlAuzcI_600x450.jpg a noise like it wants to
work but don't. Anyone have a idea what it might be ?
/ Problem / 6 way blade #2
Hydrulic fluid is OK?
Any visible rust-- smack the face of the blade with a 16 lbs. sledge on each side to break the corrosion seal if it is present.
/ Problem / 6 way blade #3
Has it been greased recently? Does the engine strain or relief open when you activate the function?
/ Problem / 6 way blade #5
It sounds like something has seized, been jammed into the pivot point, or the seals in the cylinder failed. You can pull the cylinder/s off and see if they function properly when not attached to the blade.
/ Problem / 6 way blade #6
There are not any quick disconnects on those lines are there? Should not be any, but if there are, sounds like one is disconnected. :confused3:
I used the machine today and worked the hydraulics in all ways possible, about 30 minutes into this the thing started to work. I don't know if the hydraulic oil heated up
and helped or if all the shaking around did it, but it seems ok.
Thanks to everyone who posted.
/ Problem / 6 way blade #8
:cool2:
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
JOHN DEERE 544J SUPER TRACTION WHEEL LOADER (A65053)
JOHN DEERE 544J...
17601CFL (A59228)
17601CFL (A59228)
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
