Problem / 6 way blade
/ Problem / 6 way blade #1
duke7595
S/W MO.
820 ,1520,1020 (D) 1020 (G) 1050,4020 2240
I have a problem with the angle part of the 6 way blade all other functions work ok.
The machine had been setting for several months and upon starting it, I became aware that the angle does not function either way, it makes 00b0b_TcNZlAuzcI_600x450.jpg a noise like it wants to
work but don't. Anyone have a idea what it might be ?
/ Problem / 6 way blade #2
Hydrulic fluid is OK?
Any visible rust-- smack the face of the blade with a 16 lbs. sledge on each side to break the corrosion seal if it is present.
/ Problem / 6 way blade #3
Has it been greased recently? Does the engine strain or relief open when you activate the function?
/ Problem / 6 way blade #5
It sounds like something has seized, been jammed into the pivot point, or the seals in the cylinder failed. You can pull the cylinder/s off and see if they function properly when not attached to the blade.
/ Problem / 6 way blade #6
There are not any quick disconnects on those lines are there? Should not be any, but if there are, sounds like one is disconnected. :confused3:
I used the machine today and worked the hydraulics in all ways possible, about 30 minutes into this the thing started to work. I don't know if the hydraulic oil heated up
and helped or if all the shaking around did it, but it seems ok.
Thanks to everyone who posted.
/ Problem / 6 way blade #8
:cool2:
