Problem / 6 way blade
/ Problem / 6 way blade #1
duke7595
Gold Member
S/W MO.
820 ,1520,1020 (D) 1020 (G) 1050,4020 2240
I have a problem with the angle part of the 6 way blade all other functions work ok.
The machine had been setting for several months and upon starting it, I became aware that the angle does not function either way, it makes 00b0b_TcNZlAuzcI_600x450.jpg a noise like it wants to
work but don't. Anyone have a idea what it might be ?
/ Problem / 6 way blade #2
Hydrulic fluid is OK?
Any visible rust-- smack the face of the blade with a 16 lbs. sledge on each side to break the corrosion seal if it is present.
/ Problem / 6 way blade #3
Has it been greased recently? Does the engine strain or relief open when you activate the function?
/ Problem / 6 way blade #5
It sounds like something has seized, been jammed into the pivot point, or the seals in the cylinder failed. You can pull the cylinder/s off and see if they function properly when not attached to the blade.
/ Problem / 6 way blade #6
There are not any quick disconnects on those lines are there? Should not be any, but if there are, sounds like one is disconnected. :confused3:
I used the machine today and worked the hydraulics in all ways possible, about 30 minutes into this the thing started to work. I don't know if the hydraulic oil heated up
and helped or if all the shaking around did it, but it seems ok.
Thanks to everyone who posted.
/ Problem / 6 way blade #8
:cool2:
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
Skid Steer Smooth Drum Roller (A65640)
Skid Steer Smooth...
Used 20' Container (A62679)
Used 20' Container...
Case IH 5100 12ft. Soybean Special (A65640)
Case IH 5100 12ft...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
