Pro Press Copper Crimping Cordless Tools
   / Pro Press Copper Crimping Cordless Tools #22
In my area people used to have a lot of copper but switched to CPVC. I bought a 25 year old house with CPVC and after 6 CPVC cracks or leaks every few months I finally ripped it all out and PEXd it. I am a happy camper except for the fact I started to use brass PEX fittings which may or may not last, but don't know. The last half of the job I used PEX plastic which hopefully will last till I am pushing up daisies.
The brass pex fittings are a lot thicker than copper pipe is. I don’t see that you’re ever have any problems with the brass corroding through. I usually use plastic pex fittings because they’re cheaper and I’ve never had any problems using them either.
   / Pro Press Copper Crimping Cordless Tools #23
A few years ago, despite all the "use black pipe" crowds
warnings I put together a short run of pex for air lines.
I'll admit that I was skeptical but having worked with it and came across a few forum guys that had also used it and one that worked in a commercial situation where it was used, I ran about 30' of it to a couple of hose reels. It can't get direct sunlight and my nagging leaks are at a black pipe manifold I put together rather than the pex or the FIP fittings and copper band clamp. I think the negative feelings are a throwback from those who dared to use pvc "back then" for air systems.
I'm pretty well convinced that it's just fine for air lines and any additions that I might need in the future will be pex.
16ft Driveway Entrance Gate with Tree of Life Design (A57454)
16ft Driveway...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
Deere 410L (A53317)
Deere 410L (A53317)
